Results 1 to 9 of 9
Thread: Big noob question...can regular desktops work?
    May 2004
    Northern Virginia
    I couldnt find what I read before but it had the cons of putting a regular desktop in a car. size doesnt matter to me, and i can get a p4, 2.4 ghz, 512 mb memory, 80gb hd on ebay for 350 shipped. What's the downside to this.
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    well... size, but not in your case. And power consumption, will a full blown powerful desktop you will need a decent invertor and normal PSU, with less specs you can start to consider DC-DC, even if they are more expensive.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    May 2004
    Northern Virginia
    I'm going super easy/ghetto with this, so I'm gonna buy a good quality inverter that can power the computer. It will be hooked up to a second battery which is also in the trunk. Let me know of any other cons you guys can think of. Thanks!
    The first thing I can think of is heat. It will be in the back of a hatchback (hatch has cover, windows tinted), but I know the machine will heat up pretty quickly right?
    Variable Bitrate wkolodny's Avatar
    DC
    Quote Originally Posted by Boofer97rs
    A P4 cpu puts out alot of heat. Better have good cooling.
    Don't Fear The Gurkey
    Click here to check out My Setup
    May 2004
    Northern Virginia
    I dont [I]need a p4, i can get something lower. But i figured I might as well get a 2x faster computer for 1/2 the price of a decent mini computer.
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Anything will work, its just how well they will work. There is a reason the minicomputers are 1/2 the speed for twice the price, they will work better.
    Jun 2004
    Upstate New York
    Thoughts on second battery
    Do yourself a favor and put in an isolator for the second battery so the system never draws off of the main battery. This will make sure the car will always start in the event you forget to shut everything down or are using the PC without the engine running. The alternator will still charge the second battery with the isolator in.
    May 2004
    Northern Virginia
    it will be on a 200 amp relay, which has the same effect, if im not mistaken
    666 is offline
    Mar 2004
    Quote Originally Posted by Jailer
    just wondering how do you hook up the 2nd battery in?
  1. noob question - how are LCD's measured
    By nodeel in forum LCD/Display
    Last Post: 11-25-2003, 03:08 AM
  2. A nOOB question about monitors.
    By GATrooper in forum LCD/Display
    Last Post: 10-12-2003, 03:21 AM
  3. Question about BIG 8-pin DIN
    By koyoutou in forum Newbie
    Last Post: 10-02-2003, 04:56 AM
  4. noob question
    By sugarmychurro in forum General Hardware Discussion
    Last Post: 05-19-2003, 08:34 PM
  5. Hardware question by a Noob
    By SavedSoul777 in forum General Hardware Discussion
    Last Post: 04-07-2003, 09:53 AM
