Results 1 to 5 of 5
Thread: how to get movies to play full screen on Lilliput?
    Mar 2004
    i have a 7" Lilliput and when i play DVDs it only takes up the middle half of the screen (widescreen.) since the Lilliput is 16:9, shouldn't i be able to fill the screen?
    anyone know how to do this?
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    What video player do you use? You should be able to change the settings in the player and fit to screen.
    Jan 2004
    Most Widescreen movies are not in 16x9. They're in 2.35x1 which will leave bars at the top and bottom on 16x9 screens. Unless the DVD Software has some sort of zoom feature, the only way you're getting it full screen is to get the 4x3 (normal aspect ratio - think TV) movies...
    Low Bitrate NorthGaVigor's Avatar
    God Bless America and Our President!
    Maximum Bitrate dodgetimes2's Avatar
    I have this same issue, when running at 800x600 (aspect ratio 1:33 to 1) the Lilliput will letterbox 16:9 (aspect ratio 1.77 to 1) movies, but if you change the resolution to 848x480 (aspect ratio 1.76 to 1) the movies will fill the whole screen. Now if you have a movie with a wider aspect then 1.76:1 then you will still have black bars. Guess you just gotta run 848x480, but I don't like the way somethings look at that res. (i.e. XP desktop looks distorted to me).
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  1. Winamp Vizs not working with Lilliput screen
    By d1g1tal3nvy in forum Media Engine
    Last Post: 04-19-2004, 04:59 PM
  2. MC and full screen
    By TaylorMade in forum MediaCar
    Last Post: 04-19-2004, 12:14 PM
  3. Lilliput and adding another screen..
    By Custommx3 in forum LCD/Display
    Last Post: 01-28-2004, 05:05 PM
  4. Lilliput Screen Res
    By Gremlin in forum LCD/Display
    Last Post: 12-10-2003, 05:29 PM
  5. decoded DVD movies won't play
    By cproaudio in forum General MP3Car Discussion
    Last Post: 01-20-2003, 05:33 AM
