Results 1 to 10 of 19
Thread: i'm new, just need a bit of help here :P
    cus
    cus is offline
    Jun 2004
    Middlesbrough UK
    hey guys, saw some guys install of a pc in his audi, so thought i'd try the same thing..
    main uses of the pc will be:
    1. control cds - play mp3s etc
    2. play games via a 7inch widescreen tv (already setup)
    3. watch videos via screen
    i just want to know if i can use the current setup i have in my bedroom in my car..
    it issss...
    ASUS P4S800 motherboard
    Nvidia GeForce FX 5900 Ultra
    Built in soundcard.
    120gig harddrive
    1gig ram (kingston)
    i can use a smaller 10 gig harddrive, and 512 ram aswell if needed, but i just want to know if its possible to use these part, or will i have to use other parts..
    basically just need to know which parts i can use from this site to get this setup working in my car.. OR
    tell me which parts i need to create a new setup, i'm not bothered really about performance, but it needs to have at least 10gig hdd for my mp3s, and enough from to install windows XP
    i hope you understand what i'm trying to ask because i really want to get a pc in my car to control all multimedia aspects of it.. cheers!
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    You can put any PC in a car, that one will be fine, the only limitation is power, so your CPU speed would be useful.
    You need to read around the power supply board and decide on a DC-DC based power supply or an ivnerter based one. You may need to get an external sound card if you get bad interference, otherwise that stuff'll do.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by cus
    it issss...
    Built in soundcard.
    120gig harddrive
    1gig ram (kingston)
    You made find that you need a better sound card. While some systems have decent onbard sound cards, other suck. Also, how do you plan to get the sound from the pc to the car speakers? Amp or head unit? Regarless, you will need adapters. There are mixed feelings on the power supply issue. Some prefer inverters and standard type pc power supplies, while others prefer DC-DC power supplies. Inverter and standard is the cheaper route. You will need a monitor (I see you have one already, but you may want a touchscreen?), and cables to extend monitor from trunk to passenger compartment. Are you going to mount the screen in the dash or use an existing bracket? What about mouse/keyboard? Are you going to extend, or get a wireless/RF setup? How are you going to power the pc on? How are you going to use the DVD/CD player? Will it be in the trunk, or remote (in the dash)?
    You've got a lot of planning to really determine how your setup needs to be. Base specs seem fine, but you are missing most of the details that add up to a lot of additional cost.
    Batman
    cus
    cus is offline
    Jun 2004
    Middlesbrough UK
    right, i'm glad u ask those questions because i completely forgot!
    first of all..
    processor - pentium 4 2.77ghz
    input - wireless keyboard and mouse
    power - thats where you lot come in please
    sound card - built in, but if i get interference, i can use my creative external card
    screen - built into the dash already see pic below (already wired to ps2, but getting rid of that)
    sound - i have an amp setup already, the amp runs 4 x speakers and 1 sub. its a 6 channel amp, and will run the sound directly to it
    cd/dvd player - i have a built in one, which i will mount in the boot horizontally with the pc BUT i have over 5,800+ songs on the hdd that i will just use that, also, 40+ films are on there. the cd player will be used as a back up, in case i dont have a song my mates request
    updating the system - i will be using wireless lan to connect to my mums computer to get updates etc..
    everything mentioned above i already own, its just the power that i need to sort out, so i need need for you people to tell me the best way to power my system.
    btw, i have a lot of experience wiring various products, and know everything like running speaker and power cables on opposite sides of the car..
    hope this explains more
    cus
    cus is offline
    Jun 2004
    Middlesbrough UK
    btw, the screen is now reupholstered in alcantara trim, so looks alot better!
    cus
    cus is offline
    Jun 2004
    Middlesbrough UK
    anyone know which option is the best for powering this? thankyou
    also, do the products come with setup instructions?? cheers people!
    Sep 2003
    Newark, Ohio
    Cus,
    I personally run a 300w inverter and a 300w standard ATX power supply. Alot easier to replace if it breaks on vacation or anywhere else. Any best buy, compusa, or computer shop has the parts to get you back up and running on the spot. If as DC-DC goes out, you will not be able to use your system until the new power supply is shipped to you. Also, if you need more power because you run fans, lights, etc... all you have to do is pick up a bigger power supply. Can't do that with an opus.
    Batman
    cus
    cus is offline
    Jun 2004
    Middlesbrough UK
    cheers batman great help.. so i need both inverter and power supply?
    where in the UK can i get these items from? or do you know anywher that ships to the UK for a little charge of course??
    tyhankyou for the help mate!
    cus
    cus is offline
    Jun 2004
    Middlesbrough UK
    OH BTW, batman, is your inverter run directly to your battery? and if so, does it stay on if you turn the engine on/off etc.. i already have one to run my PS2, so i can use that, but it plugs into my cigarette light, so i want to cut the wires and wire it directly to the battery, just wondering if i need to fuse it, or if the use is in the box and not the cigarette light end bit...
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    another person gets the bug .... welcome to the masses
  1. Reducing my boot time bit by bit.
    By themurph1018 in forum General Hardware Discussion
    Last Post: 11-16-2004, 07:39 AM
  2. WTB: (or trade) 8" 18 bit touchscreen
    By SuperMatty in forum Classified Archive
    Last Post: 04-11-2003, 12:08 PM
  3. Sproggy psu a bit cheaper & easier
    By TDMP3 in forum Power Supplies
    Last Post: 08-04-2002, 02:29 AM
  4. Cheap 16 (or better) bit 8.4" Touch Screen?
    By Rireal in forum LCD/Display
    Last Post: 07-03-2002, 08:07 PM
  5. 20 bit = high color or 256 ??
    By hippie in forum LCD/Display
    Last Post: 05-08-2001, 10:12 AM
