Results 1 to 6 of 6
Thread: Looking for double DIN 7 x 4 epia case
    Jun 2004
    Looking for double DIN 7 x 4 epia case, pic inside
    Hello all,
    Im getting ready to start on this carputer project. I have a 91 Taurus SHO that I wanna do this in. I found a case here that would fit here, but its only one DIN unit tall, and is pretty restrictive as far as memory & drives go. The taller ones there are all at least 8" waide, wich won't fit. So I am looking for a case that is 7 x 4 (as opposed to 7 x 2) to fit where that stock headunit & cupholder thingie is right now. The cupholer unit comes out easily and is pretty much the same size as the head unit. This car alrady has a decent JBL system stock, including an amp, so hopefully all i will need is the case & board, drives & lilliput touchscreen, and psu.
    Anybody found a case like this?
    Edit: Oh yeah, the faceplate for the head unit looks bigger than usual, but thats just the front, its all regualr behind there, and there is a plastic bridge that runs between the cupholder & head unit, which i can easily dremel out.
    Jun 2004
    Feb 2004
    Orlando, FL
    That link doesn't work. But you think about makig one, maybe out of plexi?
    Pioneer DEH7600MP, Autotek MX-800.4, JL Audio XR650-CSi, Adire Audio Shiva
    Done with CarPCs, using a iPaq 3765 PDA w/ Holux GM210 and TomTom
    Constant Bitrate chewiee's Avatar
    Kent, UK
    Travla 137
    Dont Travla do a 137 case as well that looks double-din.
    VW Mk2 Golf GTI 16V:
    Kenwood KDC-W6527 HU
    Silver Travla C134, Slot Loading DVD/CDRW,
    256MB, VIA Epia MII 12000, Carnetix 60W, Xenarc VGA/Composite TS and a GPS Mouse
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    you could make your own case out of a prototyping enclosure. Digi-key has hundreds of diferent sizes i'll bet you could find one that's the size you are looking for, or at least one that's 7x4x something longer that you could cut down. I built the case for my pc out of one. It's more work because you need to make brackets to hold drives ect, but it's the only way to get exactly what you want.
    Good luck
    Jun 2004
    Hey weird the link doesnt work but should be from l o g i c s u p p l y dot com. Weird why is that censored here?
  1. EPIA M10000 m/b & Travla C134 case fit problems
    By Bxscig in forum General Hardware Discussion
    Last Post: 04-01-2006, 11:28 PM
  2. Where can I get this DIN carpc case ???
    By numberone in forum General Hardware Discussion
    Last Post: 01-24-2004, 02:47 AM
  3. Mini-ITX in a DIN case and mini-itx Q's
    By eugenen in forum General Hardware Discussion
    Last Post: 04-04-2003, 10:52 AM
  4. Opus + Epia.. How to get it in the case?
    By ShinkunoNamida in forum Off Topic
    Last Post: 12-28-2002, 11:47 PM
  5. din unit epia
    By saletel in forum General Hardware Discussion
    Last Post: 12-19-2002, 03:40 AM
