SoundBlaster Live or Audigy are good choices for internal sound cards, as long as you have an available PCI slot. They will also provide sufficient signal to your amp, when you purchase it..I would like to get a 6 channel soundcard, and a bigger hard drive, but the PC isn't my main concern right now. My dash looks like it will fit a 7' LCD (see attached pic), but probably will need a little fiberglass/bondo work. I have no idea how to do this, so any tips or help would be great.
For the LCD bondo work...definately search around here....fabrication forum
I would personally recommend JL Audio, very clean power, other opinions differThe next thing is the sound. Any recommendations on amps I should get?
It would go from PC - AMP - SPEAKERS if you are dealing with a 4-channel amp. There is no need for a wiring harness if you plan to gut you OEM head unit for the screen. A 4-channel amp will distribute the sound without a separate head unit...Another thing I don't understand is how it gets to the speakers. Does it go PC>AMP>Wiring harness adapter?
Depends on what kind of "in-dash" DVD drive you plan to get....are you looking at a slot-loading compact drive, or a full-sized 5.25 drive? Any internal drive will need an IDE to USB converter as well as an ACTIVE USB extension (repeater) cable to connect to the PC if it is in the trunk, or more than 6 feet away. Most drives also have power requirements, but if they're internal, power can be provided (usually) from a 5-pin molex connection. To find reccommended accessories for car use, search the forums here"Another thing would be a in-dash cd(or dvd) drive. I've read about USB adapters to get it to the front of the car. Does anyone have any links/info on this?
As far as running the wires are concerned, and assuming you have your PC installed in the trunk....for a typical car, you would remove the rear seat(s) running the wires towards the driver's side lower rear door (door sills). Remove both front and rear sills on the driver's side, running the wires inside of the sills towards the front of the car. At this point, depending on your car, you may have to remove pieces of your dash to connect the wires to your proposed in-dash screen, as well as appropriate power connections under the hood.One last thing is where I would run the wires. What would be the easiest way to get them to the dash? Under the carpet?
As a general rule of thumb, search here for PC-CAR related issues, seach audio forums for good components (ie. amp/subs) to complete your setup
~FiSKARZ~
LinkBack URL
About LinkBacks
