Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Carputer integration with HUGE car audio system, help please
  1. #11
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by ColdPhreze
    You should NOT simply use a splitter on the audio out from the sound card. It will cause several things, but most importantly it will decrease both the quality and volume of the audio. You will need to invest in several quality external crossovers.
    I disagree with this, as long as you have a decent sound card that will cope with driving several amps and decent quality cables there shouldnt be a problem (and as long as you dont split the cables too many times)
    Signature: [==||========] 20% complete
  2. #12
    Constant Bitrate LeoTheHamster's Avatar
    Jul 2004
    Kings Lynn, Norfolk, UK
    Quote Originally Posted by Nic
    In which case you would be better off using a multi-channel line-driver, such as the Vibe Deltabox
    Leo
    http://www.talkaudio.co.uk
    A million people can't be wrong, right?
    Well... unless they're all from the red states...
  3. #13
    Thats kinda the problem, he's running 8 channels into 4 amps...
  4. #14
    Quote Originally Posted by no1knows
    You should also consider the fact that by using dual monitor, or monitor/TV in your situation you can display different applications on different screens, i.e. media car on yr VGA screen, DVD on the headrests.
    How do you do this? Dual monitor setup? Or do you mean actually have a seperate dvd player to drive the second video input?
  5. #15
    vancouver bc. canada
    that is a big system alot of bass, I am trying to do the same thing in my car. but why a 5.1 sound card why not a regular 2 channel sound card do the mini plug to rca conversion then go into a line driver, then into a three way x-over. i only ask this because it dosnt sound like he has the setup for surround sound and he seems really intent on having lots of music. has anyone ever measured the preamp voltage on a set of rca's form a computer I would be willing to bet it is real low I think I will measure that this weekend.
  6. #16
    Oct 2004
    acutally, the preamp out from a pc is better than most head units. I replaced my sony headunit and sound quality improved quite a bit. My brother replaced his Alpine head unit, and once again, quality improved quite a bit.
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
  7. #17
    ash
    ash is offline
    Low Bitrate ash's Avatar
    Jun 2004
    florida
    (Corect me if i am wrong) The MII 10000 has onboard vga and composite/S-video out. You can run the Vga to your 7'' and the S-video/composite to a splitter and then to your screens. It's all onboard the motherboard
    they made me laugh
    "Damn pounds. Euros and USD!" - N09
    "don't ruin my dreams! my parents did plenty of that " -Hcomplyr
  8. #18
    Oct 2004
    NY
    I have found that most pc soundcards, internal or external usually have an output voltage in the 2v range, whereas a high end head unit will be at least 4v & some are as high as 8v. this makes a real difference when you are running multiple amps. & I don't think pc hardware manufactures ever consider this as a probability, (there's a business oportunity for someone inclined to do that) you can add line drivers to help remedy this, I have done one with an external usb soudblaster extigy & it worked well., the side benifit of a setup like this is that that particular soud card will also funtion stand alone, without the pc if necissary, & you could play a different source through it with the pc off & still have volume control through it among other features.
    at this point in time I still think that an all out competion system is still better of being based on a hybrid system as oposed to a full pc front end, maybe this is just my opinion, but I have had a lot of experence with both pc car installs & competition in car audio, for whatever that's worth. check out this thread for more input on this:
    can a carputer replace a high end av dedicated system?
  9. #19
    DiB
    DiB is offline
    Oct 2004
    I have a loud system in one of my cars; 152db loud. I would think about using one of those usb flash drives as your system HD. It will be a bit slower then normal but all the vibrations from the bass wont affect it unless you build a custom HD harness to deaden the vibrations on a normal HD. I know this is one reason for me going to a carputer, my cd changer can't run without skipping.
    For your connection woes you might need a better EQ, or a line driver, or if you still have a free pci slot there are a nice selections of sound cards that can output to almost any connection type. I run all zapco gear so I just run one of their inline amp cables from the av brain to the amps. With the right sound card and eq/signal processor it's not hard unless you want perfect sound which costs several thousand.
    Look at some audiocontrol products if you aren't already familiar with them.
  10. #20
    Low Bitrate rmjjensen's Avatar
    Oct 2003
    New Jersey
    Well, if you have such an extreme setup than don't mess with a sound card honestly. Just get something with a digital output and use a digital signal processor to split the signal the best. Why?
    Pros
    -You'll have a high preout voltage from the DSP
    -You'll get the cleanest possible sound form the computer
    -You're completely isolating the grounds from the computer and the audio system
    -You won't get noise
    -You have control of the volume
    -You can plug a LOT of input devices into the DSP
    -Signal Processing
    -Dolby Digital/DTS Surround sound capabilities
    -Built in crossovers/Equalizers in the DSP
    Cons
    -Expensive - but with all the money invested in the audio system you don't have a choice
    I strongly recommend the PXA-H701 from alpine ...probably the best investment I made with my setup.
    Good luck with everything. But I have strictly a computer in mine with no issues. Was able to reach 146dB with just the 2 subs I got. Don't worry - the computer hardware will still function, just make sure it's all SCREWED down!!
  1. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  2. Replies: 9
    Last Post: 02-28-2004, 10:51 AM
  3. Car with no system..How do I wire the speakers to my MP3 system?
    By fogleroller in forum General Hardware Discussion
    Last Post: 02-14-2002, 03:46 PM
  4. car audio and MP3 cars
    By donalson in forum General MP3Car Discussion
    Last Post: 11-30-2000, 10:04 PM
  5. Is this a good computer for a car mp3 system ?
    By mprover in forum General Hardware Discussion
    Last Post: 08-10-1999, 06:37 PM
