Results 1 to 4 of 4
Thread: what hd to get??
    Jun 2004
    Ontario, Canada
    what hd to get??
    i plan to build a carputer in the near future but for now i just need another hard drive because my 40gb is overflowing and i need more space to store my music/movies,
    so i'm buying a hard drive at least 60gb+ for a carputer but what should i be looking for in the hard drive if i'm going to be using it in a carputer in the future?
    i will probably be buying it from either
    i'm going with a canadian supplier because i dont want to be raped with taxes when it crosses the border
    this will be a full service carputer, storing all my music and movies, gps nav, rearview camera, wireless network, usb dvd drive, touchscreen, powered by mini-itx and i'm thinking opus
    also i was wondering if an opus 150 would be able to power all of that stuff? and i was thinking of a c137 case cause its so slim it could be put be put in a custom enclosure with amps and i don't care about a 2.5" hd cause i know i'd lose a pci slot with that case but thats fine. i might just go with another case, not sure about that yet but ill worry about it when the time comes i just mainly need to know what hard drive i should go with i'm thinking an 80gb but i might just make the jump to 120gb cause the price difference isn't that big
    one more question, does anybody have any problems with hardware wiggling lose or skipping when their pounding the crap out of their car with a powerful audio system??
    FLAC Chairboy's Avatar
    Jan 2004
    Consider using a cheap, small used 2.5" drive for your operating system, then using a USB 2.0 enclosure with a cheap big 3.5" drive. You can put some foam under the enclosure if you do a lot of off-roading or stuff that might damage a desktop hard drive.
    Doesn't take up space in drive
    Lets you use cheap hard drives
    You might need to figure out a way to power the enclosure.
    Low Bitrate philstuf's Avatar
    Jul 2004
    To add a little to what chairboy said, there are some BIG advantages with a removable/external hard drive: You can easily take it out of your car, plug it into your main PC in your house, and quickly transfer your larger files. Wifi is good, but slower than USB 2.0 and firewire.
    With you storing a lot of data (videos, etc.), you may find yourself beating yourself up in a few months if it fills up. General rule of thumb, for me, is to purchase the largest drive that fits into my budget.
    To address your final question, I have never run into issues with connections vibrating out, but most all I use have a latch or detent in them to elliminate it. If yours do not, may I suggest zip ties to help secure them. As for skipping, I have only noticed it on CD playback, never on MP3 (Unless it was a poor encode, but that is unrelated to vibration and is IN the actual MP3).
    1995 Thunderbird
    Clarion 9375 HU, 2X CDC1255 12 Disc changer, 7500 DSP/EQ/Xover (w/fiber optic interconnects), 7501 TV Tuner/Aux
    Xtant 1001d 1 Ch, 4180c 4 ch
    7" Xenarc VGA touchscreen
    1GHz Via-Nehemiah, 250 GB HDD
    XMPCR w/TOSLink, SB Audigy NX
    Jun 2004
    Ontario, Canada
    your 250gb is external?? if so, how are you powering it?
    i found this and think i can just use it
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
  3. Why does my HD stops???
    By nl4jy in forum General Hardware Discussion
    Last Post: 02-05-2004, 11:53 AM
  4. Dying HD?
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 03-07-2002, 10:47 PM
  5. PDA cassio 105 connected to a HD??
    By prado_sergio in forum General Hardware Discussion
    Last Post: 12-30-1999, 09:55 AM
