For the LCD screen... My screen has a very specific cable, which splits into 2 video calbes (yellow plugs, you know), and one VGA cable, and one USB cable for the touch screen. So wiring up is really easy...
For the sound, there are hundreds of setups...
* You can use the aux in from your car radio
* If you have an amplifier, you can just connect the soundcard to the amp
* You could use an FM modulator (or how do you call that thingy), and switch your car radio to the correct frequency
Hope this helps...
LinkBack URL
About LinkBacks
