Results 1 to 10 of 14
Thread: mounting mobo in glove compartment
    Jul 2004
    Hello, I am new to this hobby and was wondering if there are any problems in mounting the motherboard and other computer chips and drives inside the glove compartment? the reason for doing this is so i have a stealth look. Thanks!
    Newbie DaveP's Avatar
    Jul 2004
    UK
    Mar 2004
    Maryland/NOVA
    your worst enemy....
    H E A T !
    but airflow is his crpytonite...
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Sep 2003
    Northeast Ohio
    The only problems that I have encountered are space & heat. I had to cut holes in the back side of the glove box itself to physically accomodate some peripheral components ie. PCI riser card, video card, 802.11g card. After running my system, I discovered it was over heating. My glove box is shaped like a valley with both ends closed but the top wide open and heat being generated inside. With this shape there was plenty of room for heat to escape but absolutely no place for cooler air to enter to replace it (basic thermal dynamics). The solution was simple...more holes! By cutting more holes/slots at the very bottom of the "valley" cool air was able to enter and hot air exhausted out the top. With this set-up I have experienced no overheating thus far. On really hot days I just run the A/C on high and select the floor vents till things cool down. HTH
    System:
    Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
    Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Steath is good. It reduces the chance of broken windows and missing equipment.
    Allow air in the bottom and out the top. Use a fan at the top top pull the hot air out.
    Build a custom duct it you have to.
    TruckinMP3
    Read the FAQ!
    Jul 2004
    thanks for the good advice guys! i'll try to figure out a way to keep the glove compartment cool!
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    I have it this way and that's right I had to hack up my glovebox to make it work. So essentially if I ever want to sell my car I'd have to find a new glovebox. Only problem I get is heat. I usually just turn on the AC to the coldest, lowest speed setting and that gets the job done. I doubt this will be a problem in the winter.
    Mine needs to be updated.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    I had to hack the side of my glovebox up to allow the cables to not get smashed/pull on the motherboard...I currently have a hole the size of a half dollar or a little bigger in my air duct that goes to the far right vent that blows cool air straight down onto the mobo. It is directly above it.
    Now I have not run my comp since I took my lilliput out for repair work but I was curious...is there a posibility of condensation in there? if so, what ways could I prevent it? The motherboard is open and completely exposed, its stuck to the back of the glove compartment
    CarPC install is starting to come along again...
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    I will attempt to install the carputer in the glovebox also. I have a dual glovebox. Upper is where the carputer will go. I will also attempt to dremel a rould hole in the side and install an 80cm or so fan there, with the other side a whole bunch of little holes for air flow
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    This could be solved you all went out and bought Mini Coopers. JK. They have AC in the glovebox.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  1. Mounting Direction of Mobo
    By DaRacerz in forum General Hardware Discussion
    Last Post: 07-02-2004, 02:51 AM
  2. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 09:24 PM
  3. mounting a miniITX mobo
    By lummox in forum General Hardware Discussion
    Last Post: 02-11-2004, 05:27 PM
  4. Mount TFT in glove compartment
    By way2gud4u in forum LCD/Display
    Last Post: 08-24-2003, 06:25 PM
  5. help me out with a really small mobo
    By schrodos in forum General Hardware Discussion
    Last Post: 07-04-2001, 05:54 PM
