Results 1 to 7 of 7
Thread: Introduction: Saturn SL2 owner. Simple MP3 audio
    Jul 2004
    Hi to all of you carputer and MP3 car audio people! It's nice to see this forum. I have obviously just now discovered it. Many of you have great mods and solutions. Really good stuff!!
    I have a 99 Saturn SL2 with the factory single CD and "premium sound" set up which has the EQ built in. All I really want to do is add an Aux input if I can get away with it. I am not yet sure which route I have to go. I might have to actually replace the stereo itself. I don't know if the unit I have uses the standard 9 pin GM slave unit input that I have read about. I suppose I will need to find out.
    I'm sure after I search here I will find out after some research.
    If anyone has any immediate hints I'd certainly entertain them.
    DC
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Try http://www.soundgate.com . They may have what you need.
    Oooh another Saturn owner Welcome.
    The connector should be a generic GM for Delco CD changers.
    1995 Saturn SL2
    Carputer removed.
    Pioneer DEH-P880PRS head unit
    Soundstream Rubicon 600-4 4 Chan Amp
    Diamond Audio D661s components w/Active Crossovers
    MB Quart RAA1000 monoblock amp
    2 Alpine Type R 1041D 10"s
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    welcome to the addiction
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Here's another place to check - they are very helpful if you need to email them.
    http://www.logjamelectronics.com/
    Jul 2004
    Quote Originally Posted by Tuanies
    Thanks for your response!
    Did you use the PIE GM10-AUX connector?
    I dont have the changer but I have the single CD player with the AX (aux) button and thus I can add 2 (yes two) wiring harnesses. Is this the route you took?
    DC
    No, I'm using an aftermarket head unit with Coaxial in, I hate factory equipment.
    1995 Saturn SL2
    Carputer removed.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. 2002 Saturn SL2 install
    By Yuriy in forum Show off your project
    Last Post: 10-08-2006, 09:45 PM
  3. connecting a powersupply to saturn SL2
    By BlinderBomber in forum Newbie
    Last Post: 03-22-2004, 09:19 AM
  4. Connect hand held MP3 player to car audio system?
    By jasonwood in forum General Hardware Discussion
    Last Post: 10-31-2001, 12:30 AM
  5. MP3 in Saturn (96 )?
    By JackMode19 in forum General Hardware Discussion
    Last Post: 03-02-2001, 12:48 AM
