Drivers that ship with it for some reason didn't work for me either had to search the forums for other drivers. Try the one's listed here http://www.egalax.com.tw/Download.htm
Hopefully that will solve your problem
I purchased a Lilliput touch screen monitor and tried it at my workplace. It worked fine under that environment using Windows 2000. However, when I used my Neh. M1000 motherboard with XP Pro on it, the drivers do not work for touchscreen. Also, I can not get the properties of the display in XP to go lower than 800 X 600. I tried to change my monitor drivers, and it only will let me install default monitor. I can not get the monitor drivers to work. Can someone please help me?![]()
Wow! That was pretty quick. Thanks Jailer. I will try it.![]()
Timing is everything in life
