Results 1 to 10 of 14
Thread: Ok think I got most things set... cable question tho.
    May 2004
    Ok Ive decided on most items so far... however I will be putting my PC in the trunk and the display in place of my double din stereo.... but how do I get the video signal and USB all the way up there? Can I get extension cables? If so where is the cheapest place. Also where is the cheapest place to get a case and VIA ITX MB in the US? I checked out logic supply, and their decent, but some things like the HD and DVD is way over priced, and Ill get thoose through newegg.
    Also if I can get extensions for the cables that long, wont there be major quality loss in the signal quality too? What is the answer to this?
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    I have extended all my cables and things are fine. For USB I added a mini usb hub (self powered) to the middle console and then ran the cable from the trunk to that. Then I could branch out to whatever else I add to the dash area.
    Once you go too long though, USB needs a power boost - might want to check into thel imits of the extension cable length. I had no probs tho. And my vid signal extended all the way up to the dash from the trunk without problems or loss of signal.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by Dulanic
    I have both my VGA and USB extended from the trunk with no loss in quality. I have the thick VGA cable which kind of sucks running it through all the panels but it works just fine.
    Installed.
    -GPSSecure- - GPS Tracking
    May 2004
    Whats a good place to get the extension cable for it? Also, will VIA MII boards onboard video support the correct resolution of the lilliput 7" LCD?
    USA
    I don't much about the VIAs but I just bought my cable from a local computer store. Cost me a little less then a $1 a foot.
    Installed.
    May 2004
    Quote Originally Posted by brady
    What was your reason for going MATX? Im still not sure 100% Im going VIA... it just seemed easy and cheap, and would do most the stuff I wanted.
    USA
    ATX isn't all that expensive. I don't like having everything integrated on the motherboard. ATX can be much faster.
    Like you said you can pretty much do everything on the VIA that you would need in your computer.
    Installed.
    Low Bitrate savante's Avatar
    Jul 2004
    Chicago
    Would it be better to extend both the vga and usb cables separately with shielded cables or extend the breakout cable by using one of the 9 pin mini din extension cables and then separating the signal at the end, possibly in the trunk.
    Or does this not even matter?
    USA
    Quote Originally Posted by savante
    I would just extend the USB/VGA cables seperately.
    Installed.
    Jul 2004
    Chicago
    Ok, when I get to that point, I will go that route.
    Thanks for the info.
  1. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 01:27 PM
  2. IDE Cable Length Question.
    By BeAR in forum General Hardware Discussion
    Last Post: 10-18-2001, 01:48 PM
  3. audio cable question
    By daver in forum General Hardware Discussion
    Last Post: 10-04-2001, 02:04 PM
  4. Wiring Question (long)
    By mtmsol in forum General Hardware Discussion
    Last Post: 05-18-2001, 10:39 AM
  5. Alltech Elc.LCD cable question
    By subarump3 in forum General Hardware Discussion
    Last Post: 11-29-2000, 10:51 PM
