Results 1 to 10 of 18
Thread: Compatable cpu heatsink/fan
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    I need a Heavy Compatible heatsink/fan for this motherboard..
    http://www.syntaxusa.com/catalog/pro...roducts_id=108
    any help?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Feb 2004
    Charlotte, NC
    would something like this work?
    http://www.directron.com/foxconn370a.html
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    yes, probably.
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by cadence117
    No, thats for AMD. You would nave no way to attach it.
    Jul 2004
    It will fit. Both the motherboard and the fan are type Socket 370. It'll work just fine. The reason that the cooler says "AMD" is because most people buy either Intel or AMD and they are usually not compatible. As long as the fan is Socket 370 then it will work with that motherboard.
    Progress Bar
    <|---------> 5%
    [See my Worklog] (project on hold...)
    Feb 2004
    Charlotte, NC
    can anyone else confirm that? (no offense jonac)
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Not exactly,
    You will probably have difficulty finding a heatsink for that board. Even if it says is a socket 370, looking at the picture, the socket is missing and the cpu is soldered to the board. Since all heatsinks for socket 370 are designed for attaching on the socket...
    It's hard to advice without the board, but I think you will have to go gheto on this. The original heatsink/fan combo seams to be attached to the board by that 4 little white pegs ( not sure about the correct name ) . My guess is that they are similar enough to vga heatsink attachments, and so you might find some old vga, and steal its heatsink/fan for your board.
    If you find any other way to get a good and even pressure against the cpu, any heatsink will do the job, the one in your link included.
    Brave
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by Bravellir
    I didn't spot that...! How can they call it socket 370 when there isn't even a socket...!
    http://www.geek.com/glossary/glossary_search.cgi?socket
    Why don't they call it "holes-in-the-circuit-board-370".
    Feb 2004
    Charlotte, NC
    Not exactly,
    Brave
    anybody got suggestions on just how to do that??
    Dec 2003
    Porto, Portugal
    Do you have the board with you? can you post some close pics of the cpu area with and without the original heatsink ?
    And the exact distance between the four holes in the board ?
    Status -->
    BraveCar 2.5
  1. whats a good cpu for next project?
    By dman in forum General Hardware Discussion
    Last Post: 08-01-2004, 01:56 PM
  2. CPU Swap question
    By Mitokondria in forum General MP3Car Discussion
    Last Post: 07-25-2004, 03:31 AM
  3. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:14 AM
  4. Grounding CPU cleared buzz
    By SirCyRo in forum General Hardware Discussion
    Last Post: 08-20-2002, 01:53 AM
  5. CPU Cooling
    By Dartman111 in forum General Hardware Discussion
    Last Post: 06-04-2001, 01:56 PM
