Results 1 to 5 of 5
Thread: Critique My Choice of Components?
    Jul 2004
    West Midlands, UK
    Before going ahead an ordering does anyone have any opinions on the hardware I have selected. Good or bad... just as good cheaper alternatives? My budget is approx 1k and I'm just about there.
    Motherboard and Processor
    VIA EPIA M10000
    Hard Disk Drive - 60Gb
    Hitatchi Travelstar 80GN
    Memory
    Kingston 512Mb PC266
    DVD Drive (slim)
    Toshiba SD C2612
    7" Touchscreen VGA
    Gain/Xenarc 7"
    VIA PCI Riser Card
    Opus 150w PSU DC-DC 150w ATX PCB
    PCI Graphics Card (2 VGA)
    PNY Verto/GeForce2 FX5200 128Mb
    PCI Sound Card
    Audigy 2 ZS Plat/Pro
    USB Hub 2.0 4-Port
    Targus Ultra Mini Hub
    Power Cable - 8 gauge
    IDE to USB for DVD Drive?
    IDE Cable - Round for HDD
    Mini Jack to RCA Cables
    ARAT Bracket for e36 BMW
    I'll try the onboard graphics first but if I'm not satisfied or get a second screen I'll got the PNY gfx card as this has a second VGA.
    The reason for the selected sound card is for SQ and for connectivity between pc and my amp. This card has an external i/o box.
    Gain/Xenarc as if I have the roof down on my car during a bright day I at least want to be able to see the screen!
    Toshiba slim DVD is cheap! This will be mounted down the front of the car...
    Opus - very good - 'nuff said.
    Targus mini hub is cheap and pretty small.
    ARAT bracket as I don't want to hack the dash.
    EPIA M10000 - I won't be needing PCMCIA like on the newer EPIA II ones. Should have enough processing power.
    Hard Drive - 60Gb is enough for my apps and mp3 collection!
    512Mb will be enough memory for the car PC.
    Case - I could do with input here... If I decide to use the two PCI card with the VIA riser then these will be facing away from the mainboard. Not sure what case? May have to build a custom one?
    Thanks.
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    Quote Originally Posted by ZimZimmer
    Thanks.
    Take a look at the Casetronic Travla C137. It has 2xPCI slots, but you're going away from that DIN-size with PCI card. If you're looking for more Graphics power there is a P4 Mobo with an ATI graphics chipset that will be out very soon...
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    Jul 2004
    West Midlands, UK
    Quote Originally Posted by euro320i
    Thanks for the input, that case is looking ideal.
    I decided against DIN-size as I want the functionality of PCI.... P4... Hmmm it would prob be a more suited choice in the long run if I choose to expand the system past mp3 and dvd playback
    Feb 2004
    There's AMD mobo's with integrated GeForce already out if you're looking for graphics power. asus a7n8x-vm is mini-atx with nForce2 IGP.
    Jul 2004
    West Midlands, UK
    Quote Originally Posted by kai445
    Thanks. If I build a new home PC I could use this PC I'm using now, in the car. It's a AMD XP2600, A7n8x-x, 512Mb DDR400, Gainward 128Mb DDR with Nvidia ti4200 chipset, 120Gb HDD. Prob a bit overkill for my current requirements but an option for later? I may well find the M10000 is fine for my current needs tho and not bother with the PCI gfx card. I very much doubt I'll be wanting games, etc in the car.
  1. Critique my plan
    By Kidane in forum Newbie
    Last Post: 08-01-2004, 01:46 PM
  2. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
  3. Does anyone in AUS have the coilcraft components???
    By odin836 in forum Power Supplies
    Last Post: 06-28-2002, 10:09 AM
  4. Motherboard choice
    By Paladin in forum General Hardware Discussion
    Last Post: 06-24-2002, 11:50 PM
  5. components?
    By Ryndel in forum Power Supplies
    Last Post: 03-22-2002, 05:59 AM
