Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Slim DVD & IDE to USB - DVD QLTY
    Jul 2004
    West Midlands, UK
    Okay I'm sussing this out.
    Slim DVD drive down the front of my car - plugged into a USB 2.0 hub I'll have down there too. So I need an adapter for the slim DVD to IDE. Then IDE to USB. Fine...
    However through these adapters into USB, will DVD playback experience poor quality or will it run smoothly? Would an external USB 2.0 DVD drive be better?
    Mainboard will be a M10000. The DVD drive is just the average notebook one.
    Thank you.
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    USB or Firewire enclosure for slim DVD/CDRW drive
    Take a look at this thread to find an external case for your notebook drive. I think it would be the cheapest route. I have the one from bixnet and the DVD quality it just as nice as my other DVD players.
    Jul 2004
    West Midlands, UK
    Thanks for the thread. I managed to find that one earlier in a search but didn't pay a great deal of attention to it - doh.
    I've been taking a look and the USB 2.0 external drives aren't that expensive.
    I'll need to get the dimensions but both AOpen and Iomega have some nice products.
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    I have my panasonic dvd-rw up in the dash buried by the shifter. DVD playback is as smooth and problem-free as i would expect from any dvd drive. I used a ide-->usb2.0 converter in the enclosure found at (http://www.akida.net/.sc/ms/dd/10917...D-Dark%20Gray-) Used the enclosure/fan for a hard drive case/cooler. And i got the slimcd-->ide converter from (http://store.yahoo.com/directron/cddvdadapter.html).
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Isn't firewire better than USB 2.0 for HDDs and DVDs??
    I've heard it has more stable speeds and won't limit ur bandwidth for other USB devices...
    Does the USB bandwidh concern each port or all USB ports on a motherboard?? Each port has it's own bandwidth?
    Mar 2004
    Milwaukee, WI
    I'm not to sure, but i have a powered 4 port usb hub at the end of a 15ft cable going to my carputer in the trunk, all ports are used, one being my dvd drive. And it plays dvds just fine. So whatever that means (3 other devices are IR receiver, powermate, and touchscreen... so maybe that doesnt mean too much)
    Jun 2004
    GREECE/Athens
    But if u have an audigy usb too???
    Jul 2004
    West Midlands, UK
    Quote Originally Posted by DjBac
    Good question....
    Jan 2004
    Florida
    FireWire 800 is the latest FireWire standard I have heard about and it has a throughput of 800 Mbps as opposed to USB 2.0's 480 Mbps. If I remember correct the highest throughput of IDE is 133 Mbps so both USB and FireWire will easily work as an IDE converter. Although FireWire is less software dependent and more hardware dependent so you are usually much closer to it's max speed than with USB 2.0.
    About USB bandwidth being a concern, it all depends on your motherboard or USB card. Some times all the USB ports on the motherboard are their own port but usually they have two USB ports that get split amongst the rest.
    Jul 2004
    West Midlands, UK
    Quote Originally Posted by sssssss27
    Thank you - very helpful info.
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 12:50 PM
  2. Slim Panasonic DVD & a HD thru USB Hub?
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 06-28-2004, 09:08 AM
  3. USB to ide adapter + Toshiba laptop dvd drive
    By carprowler in forum General Hardware Discussion
    Last Post: 06-25-2004, 12:49 AM
  4. Buslink slim usb 2.0 dvd rom
    By amrit50 in forum General Hardware Discussion
    Last Post: 10-10-2003, 04:38 PM
  5. Slim External USB DVD?
    By chut in forum General Hardware Discussion
    Last Post: 08-28-2003, 07:40 AM
