Results 1 to 10 of 11
Thread: moving from home to car..
    Aug 2004
    Hi, i'm new here and pls forgive any stupid questions.
    I want to move my destop pc into my car, Acura 3.2 TL t-s w/navigation system. I'm planning to use the current GPS screen, and probabbly gonna install a switch so that i can choose whether i wanna get input from the GPS or my computer.
    For the size of the casing, i'll probabbly try to squeeze it into a smaller box to save space.
    Ok, as a start, i have power problem. Shall i get a new power supply that will feed from cigaratte lighter, or shall i use an inverter to get 110V?
    also, how do i connect RC to VGA so that i can connect the screen to my pc?
    lastly ( at least for now... ), how do i adapt my pc so that it will accept the touch screen ability??
    Omg, sorry for all the questions..
    Thanxxx
    Tejo
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by sutejok
    This is one option.
    This is another equally valid option. The choice is yours.
    You can't connect VGA to RCA. You'll need a video card with TV out if the current screen accepts composite video. Either that or a scan converter.
    Insufficient information. What kind of touchscreen device do you have?
    Thanxxx
    Tejo
    Aug 2004
    Quote Originally Posted by Rob Withey
    What problem that i may be facing on each option? is there any?
    Btw, how do i choose what power supply is compatible with my motherboard?
    I have an old Dell dimension
    Super Moderator xBrady's Avatar
    USA
    What kind of motherboard do you have? AT, or ATX?
    Installed.
    -GPSSecure- - GPS Tracking
    Aug 2004
    Hmm. AT is the bigger one rite? and ATX is the smaller one?
    Its an AT.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    ATX has a 20 pin (10x2) power connection (from motherboard to power supply), AT has two 8x1 pin connectors.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Aug 2004
    ow, so any power supply with two 8x1 pin connector will be fine?
    Aug 2003
    Essex, England
    Are you POSITIVE you have an AT computer. How old is it (bearing in mind that I had a P166 that was ATX form factor)
    Crack open the case and have a look at the power supply connector, and see which it is.
    If it's AT (two 8x1 connectors) the only way is going to be with an inverter. If it's ATX, then that opens up your options slightly.
    Garry
    www.aimee.cc
    Aug 2004
    i checked it and its an AT (two 8x1 connectors).
    one more thing. Is there a way to make my VGA card to lie horizontally? pararrel with the mother board instead of perpendicular to it. If there is such thing, what is the name that i can search for..?
    Aug 2003
    Essex, England
    OK, you will need an inverter.
    As it's an AT computer, I therefore presume it's a PCI graphics card. You can get a PCI riser card which will position it over the motherboard.
    Garry
    www.aimee.cc
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. Power problems with car computer :(
    By Bitflip in forum General Hardware Discussion
    Last Post: 04-26-2004, 04:13 PM
  3. off the wall ideas
    By bubbrubb in forum General Hardware Discussion
    Last Post: 04-20-2004, 03:19 AM
  4. Tinytrak information ( add lojack to ur car)
    By moahdib in forum General Hardware Discussion
    Last Post: 03-16-2004, 11:04 PM
  5. The melbourne car show
    By magnetik in forum General MP3Car Discussion
    Last Post: 03-13-2002, 06:05 PM
