Quote Originally Posted by nl4jy
One thing you might want to concern. FM modulators w/ power usually distort your FM reception. I used to install a switch in between the 12v line so I can turn on and off the modulator whenever I need it. SNIP
The Audiovox unit that I use Ships with thae power switch assemble and is covered in the install instructions
