Results 1 to 10 of 10
Thread: Voltage Gauge?
    Aug 2004
    Voltage Gauge?
    I am planning a CarPC and wondering if there would be a way to monitor voltage at different points using some sort of software and hardware and where to find it.. What I will be wanting is to monitor voltage at 2 different batteries as well as Alternator Output voltage.. Is possible to do? Thanks for all the help!
    Newbie Zensay's Avatar
    May 2003
    Denmark
    Pc scope would might do the trick for you, but it is expensive.
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    I wonder if OBD-II can register the voltages?????
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Aug 2004
    It will be going in a 93 Ranger so I dont think obdII will work since I dont believe the Ranger has OBDII.. Already thought about that
    FLAC Chairboy's Avatar
    Jan 2004
    Radio Shack was closing out a multi-meter with serial output for dirt cheap a couple years ago, you might check eBay.
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    have a radio shack digital mm in my hand right now . the catalog # is 22-805
    happy hunting
    Jul 2004
    Ohio
    They have a new one listed for $70
    PC Interface 46-Range Digital Multimeter
    $69.99 Brand: RadioShack
    Catalog #: 22-812 Model: 22-812
    http://www.radioshack.com/product.as...%5Fid=22%2D812
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    You're looking for an A/D converter. You can find PICs these days that have several on board. You'll might have to make up a suitable analog scaling section to interface with car voltages but beyond that it should be fairly smooth sailing.
    Aug 2004
    Great thanks for the help guys! I am going to go take a look at these things and see if I can figure something out.. Thanks again!
    Constant Bitrate Avalerion's Avatar
    Jun 2004
    Hamilton, NJ
    OBD-II does tell you the voltage of your battery. Autoenginuity (the one I use) shows the voltage live - you see a difference when the alternator is running vs. car off with pc on. 13v+ vs. 11-12v...
  1. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 10:01 AM
  2. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  3. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
  4. question about relays and high gauge wires
    By Heedunk in forum General MP3Car Discussion
    Last Post: 05-10-2001, 12:13 PM
  5. DC-DC psu and high capacity HDD
    By GrahamS in forum General Hardware Discussion
    Last Post: 12-19-1999, 06:44 PM
