Results 1 to 6 of 6
Thread: CarPuter & Bass Question
    Aug 2004
    I am tempted (ok itching) to install an MP3 system in my GMC Jimmy. The problem I forsee is with the current system I have in the vehicle. (and place to mount it) :P
    I am able to skip CDs with a solidly mounted Sony CD Player right now, using 2 old school MTX Blue Thunder subs and a Pioneer amp. (attempted foam cushion on the head unit as well, helped a little - also another Pioneer head unit attempted before this one) Am I just asking for crashed hard drives to attempt a CarPuter for MP3s?
    I'm considering using standard HDs instead of laptop drives... is this a bad idea?
    Any input on mounting / installation to avoid this appreciated!
    I didn't see any real answer related to full-size drives in my search - just some odd problems, even with the 2.5 or 3.5" drives.
    I have excess standard equipment, and like the availability of PC equipment rather than laptop (proprietary) should something go wrong.
    -Side note: as a test I'll use an inverter to make sure things are going to work before building the production system for the vehicle.
    If all goes well - I may just use an inverter on a standard PC - Ghetto is my friend. =D
    Newbie jyopp's Avatar
    Aug 2004
    Gainesville, FL
    Definitely use a laptop drive. There are a lot of reasons relating to power consumption, voltage, shock tolerance, and heat.
    • Laptop hard drives use a LOT less power
    • Most laptop drives use 5V, not 12. You'll save money on the PSU.
    • Laptop drives are generally rated for >100 G's of operating shock
    • Laptop drives run cooler and have better heat dissipation
    Note that laptop drives are rated for operation in conditions that head units just aren't. It shouldn't be a problem.
    Whatever you mount, you can do it anti-shock anyway. If you're worried about constant vibrations or disturbing shocks, you should try to get a fanless motherboard so you don't have to worry about fans dying. For the Hard Drive, I'd get a 2.5" -> 3.5" adapter or drive rails and use a few layers of double-adhesive weather stripping or somesuch to mount the rails to your enclosure. That should help minimize the vibration coming from the speakers.
    Newbie Gooche's Avatar
    Aug 2004
    Baltimore, MD
    I had a CarPC which was in a BookPC case for a couple years now (since 2000). It had full desktop harddrives in it. I never had any problems with the unit crashing and this is over cobblestone roadways in Baltimore, MD with 2 12inch Rockfords blasting right next to it.
    That being said if you only have those to use and are on a budget go ahead and do it, but as jyopp said it would be better to use the laptop drive based on the shock rating...hey you never know!
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    I'm using a laptop drive as the main hdd for the computer, and a 3.5" hdd as my media storage. It's in a plastice firewire enclosure just sitting under my seat (horizontally), and I haven't had any problems yet. I think if you have a cushion under it (just glue some thick carpet to the bottom), it'll be fine.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    FLAC ppgt94's Avatar
    May 2001
    If space isn't a issue a 3.5" is pefectly fine. I've dropped drives that still work. In fact I totalled a car with a carputer running (3.5" HDD) almost three years ago and it still works today!
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    Duh, Its a Sony!!
  1. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  2. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
  3. Replies: 5
    Last Post: 02-02-2004, 10:52 PM
  4. Replies: 3
    Last Post: 11-03-2003, 11:41 PM
  5. Is bass bad for Carputer
    By Rafster in forum General Hardware Discussion
    Last Post: 10-09-2003, 08:42 PM
