Supermike, so you mean having the faceplate seperated from the headunit its self? if so that is a very good idea! One I might persue in my own carputer project.
I was going to go without a HU, but 2 weeks without a radio changed my mind. Having a radio you can turn on and get music regardless of the state of your carputer (mine is down right now, and will be for some time) is nice. You could remote the faceplate of the HU and mount it almost anywhere it will fit. I have mine sitting sideways under the car-puter in the dash and the faceplate is mounted where it fit on the center console. I have seen some cool installs where the faceplate was mounted in the visor as well.
[ MP3CarPC.com :: Digitize your in-car experience ]
* what happened to my sig and avatar :confused: *
You need a good quality lead.Originally Posted by GWRedDragon
Use a multimeter to check the resistance on the length of the sheilding - it should be as close to 0 as possible. The first (good quality, short) lead I used had a high resistance for some reason and I ended up using a 10 metre lead with close to 0 resistance. However the first, short lead was pretty cr*p!
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
Super Mike,,
how do you wire up the faceplate seperate from the HU? That sounds like a very cool idea.
