how bout dual alternators one to the seperate battery in trunk for battery, and 500 cca isnt xactly that much you could prolly findbetter.
http://www.dcbattery.com/optima_yellow.html
http://www.dcbattery.com/optima_red.html
It'd prolly cost 360$ for a new 180 alt and a spare optima battery.
of course it depends on your vehicle
In your BIOS you can make HDs stop spinning after a certain amount of time, so they wont over heat if you use laptop 2.5s, you can put the computer into standby, and most monitors into powersaving mode.
LinkBack URL
About LinkBacks
better.
, and the next morning the truck started fine and the laptop was still on and going. I have a 900 ccamp autozone gold battery(1 year old). So I know theirs a way here. BTW their is no need for the second alternator. Just a diode off your main battery terminal to a second battery will charge the second battery with out and power pull coming from the first battery.
