Yo,
I'm trying to setup a computer in my car so I am able to play music off it and use it to play vidoes too. Reading through various posts and other material I've heard many ways to achieve this.
Basically this is what I'm thinking
First I'll need to build a little computer ( one of those ITX ones )
Second need to get a touchscreen monitor
That the easy bit what I find hard is where is the screen going to go, how is the computer going to be hooked up to the in car speakers and finally how is the puter going to get power.
Regarding power I know you can either hard wire it to the engine or use a power inverter ( connecting to cig lighter) . However I come a bit stuck when thinking how I will connect the computer to the cars audio system. The car has a basic head unit which can be seen here http://defaced.net/simon/cars/newgol...t/dashkit1.jpg ( note that isn't my car). I'm not sure how you would connect the computer to the cars audio :confused: unless there is a special headunit and I'm not too keen on using an fm modulator since I guess the sound would drop
Thanks would appricate any input.
