Results 1 to 10 of 13
Thread: Futur Setup, Is it OK!
    Aug 2004
    Here is my futur setup, can somebody chack if it's ok please!?
    Thanx
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    My suggestions is to get a Morex/Travla mini-itx case with a 60W PSU inside it, and get yourself a Carnetix CNX-P1260
    Otherwise, get yourself an Opus. Either are the best options on the market, I wouldn't get anything else from experience.
    As for the screen, I personally prefer the Xenarc over the Lilliput, as I have seen/used both, and the Xenarc is much better in both image and build quality.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Aug 2004
    Thanx for the fast reply!
    Thanx for the Power Supply solution, i'll buy an Opus ps. But for the screen I have the Lilliput screen and I have a question concerning that. Can i plug the screen on the Red and Black wires from my old radio. Or I need to buy something.
    Thanx again for the fast reply! Thanx for the Power Supply solution, i'll buy an Opus ps. But for the screen I have the Lilliput screen and I have a question concerning that. Can i plug the screen on the Red and Black wires from my old radio. Or I need to buy something.
    Aug 2003
    Essex, England
    I would (and have) hook up the screen to the 12v wires coming from the power supply, otherwise you will probably get electrical noise on the screen.
    Garry
    www.aimee.cc
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    Maybe I'm lucky, but the Lilliput "egg" thing seems to regulate the power pretty well...?
    Aug 2003
    Essex, England
    I've used the "egg", and I have found that it introduced noise onto my screen (wavy lines going up and down it), but the moment I hooked it up to the output from the Opus, it was perfect, no flickering, lines or any brightness modulations at all
    However, your mileage may vary
    Garry
    www.aimee.cc
    Aug 2004
    Good to know, thanx guys!!
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    Yeah that looks like a pretty basic install to me. Also I would not power the screen off the car's power directly without some sort of regulator. I tapped off my Opus.
    Mine needs to be updated.
    Aug 2004
    Power Question (Inverter)
    Just for information, can you Power the Lilliput Monitor with an Inverter, like this setup:
    Aug 2003
    Essex, England
    You are not powering it from the inverter. You are sending unregulated power to it.
    Get yourself either an Opus, or a Carnetix CNX-P1260 (if the case you're getting has a 60W DC-DC PSU in it already) and do it right
    You will thank us later
    Garry
    www.aimee.cc
  1. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 09:41 PM
  2. Renault Laguna Puter Setup check
    By Noctris in forum Newbie
    Last Post: 05-24-2004, 05:05 AM
  3. Custom Indash setup?
    By tokhss in forum Newbie
    Last Post: 04-21-2004, 09:26 PM
  4. new setup pics
    By freestyler in forum General MP3Car Discussion
    Last Post: 06-06-2002, 12:08 AM
  5. Arrg! Problems with my new mp3 car setup...
    By MisterTwo in forum General Hardware Discussion
    Last Post: 06-05-2002, 01:14 AM
