Results 1 to 10 of 15
Thread: Idea Xbox+TFT
    Aug 2004
    Idea Xbox+TFT
    i was wondering would it be possible as xbox's are like now 100 at amazon and a mod chip around 30. Would i be able to put a modchipped xbox in my car attached to a 15inch tft monitor to be able to play DVD's DivX and MP3's though the stereo. A convertor would be needed for the Xbox->TFT monitor through VGA but what else would be needed like power adapters and convertors??
    Aug 2004
    XBox -> VGA here: http://www.digital-x.de/KNOWHOW/XBOX...a_box.htm#9999
    Be sure and mount that XBox HDD vertically as horizontally it will more than likely get nice scratches on the platters.
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by marco0009
    No need to convert to VGA (unless your LCD does not have composite in) Xbox has composite out. Three years ( 3 carputers, too) of carputing and a rough car accident I can say your HDD will most likely be perfectly fine mounted either way.
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    no need to chip it, just tsop it for free
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    rather than taking someone else's opinion on this i would for this information ... huge debate dealing with this. some say a vertical mount would put the arm motor in constant stress trying to keep the heads in a steady position. read up on it before you make your own decision given that its probably harder to find an extra x box hdd than a normally formatted one
    don't worry i know i usually don't make much sense
    Mar 2002
    You'll need an inverter to power the X-Box, but I don't see you needing anything else, except maybe a controller extension cable if you want to have the X-Box in the trunk and the DVD IR reciever in the front.
    If you're good with computers (building/upgrading), you might consider going a soft-mod route (no soldering or expensive mod-chip needed). More details in the www.xbox-scene.com tutorials section.
    Newbie longwoodtrail's Avatar
    May 2004
    Montgomery, AL
    Quote Originally Posted by sagekoala
    Try it out, just make a backup of your hdd, they are dirt cheap these days, so take it, make an exact copy of it, and store it somewhere safe. There are complete tutorials for this type of stuff, specificly hdd at http://www.xbox-scene.com/articles/hdd-install2.php
    WTF?!? You did what? With who? Why?
    Current Carputer... 20GB iPod, I am working on an upgrade though!
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    Quote Originally Posted by hevnsnt
    you can only tsop flash v1.0 and v1.1 which are really hard to find these days. Second i have done the vga mod, and it doesn't work on all apps and games(some work, some just look green). Having modded over 20 xboxes i can tell you right now that "no solder mods" wont work for you. Apart from being the lazy aproach, those things suck ***. IF you knock them hard they will move and lose pin connection, and you have to realign them. So in a car inviroment they are usless.
    So basicaly what you need to do is:
    Do the inverter thing.
    Extend a controller port to the front of the car(they are just usb ports). and connect the Ir reciever for the dvd remote. (This works great for Xbox Media Center)
    Then just get a cool composite screen for your car like say this one http://www.mp3playerstore.com/stuff_...al/TM-7300.htm
    For the power button you can try to extend it. IF it doesn't work then use a relay.
    That will take care of everything for the car.
    As for the xbox, you can mod it yourself (its not that hard). If not then buy a modded one.(pm me, i can sell you one.)
    Stick a nice 120gb+ drive in it and install xbox media center and Dvdxfree.
    If you want to get a little crazy you can add a wireless ethernet bridge to connect to your home network for file transfer or internet use.
    And of course emulators are a must. Load up some nes and snes emus and roms to play while you drive... err while your parked. For this you would need to extend additional USB ports to the front so you can connect the controllers.
    Good luck and email me at [email protected] if you have any questions.
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Puerto Rico
    oh i almost forgot to mention that Xbox media Center looks really good on TVs and composite LCDs, so you will not need VGA.
    S2000 Carputer
    Low Bitrate Aksor's Avatar
    Mar 2004
    Ottawa, ON
    You can TSOP flash all the way up to Ver1.5! I know cause I did plenty.
  1. modified xbox instead of a PC?
    By hydraulix in forum General MP3Car Discussion
    Last Post: 12-05-2005, 01:14 PM
  2. Linux Build or Xbox Port???
    By boschk2002 in forum FrodoPlayer
    Last Post: 01-09-2005, 02:43 PM
  3. Security idea - hide the HU
    By jaeger in forum General MP3Car Discussion
    Last Post: 08-23-2004, 01:17 PM
  4. Replies: 2
    Last Post: 06-18-2002, 05:31 PM
  5. Cool TFT idea!
    By lstrunk in forum LCD/Display
    Last Post: 08-31-2001, 06:24 PM
