IMO:
Get a Xenarc, not a Lilliput. In my experience and opinion, they are better than the Lilliput (especially if it is going to be mounted where there is some sunlight hitting the screen - plus the Lilliputs can break just by looking at them funny)
They are available right here on MP3Car. So is the Opus 150W, which will more than likely be fine. People here are running 3.2GHz P4's from the 150W Opus!
I recommend something along the lines of a nForce2 mATX board and an XP processor (1700+/2500+), 256mb-512mb RAM, and a non-fluid bearing harddrive (unfortunately these are becoming harder to find - i have had a fluid bearing give up on me last winter, replaced it with a sleeve bearing and it's been fine since)
From computer, you will take a 3.5mm to RCA cable, then you can just split it into the two amps.
All the other computer parts/cables are all standard
Any more questions, just ask
Garry
LinkBack URL
About LinkBacks
