Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Controlling garage door ...
  1. #11
    Central NY
    how are you going to detect the status of the lights etc? Thanks!
  2. #12
    Low Bitrate migrane's Avatar
    Windsor, Ontario
    Talking
    Quote Originally Posted by electron
    Since I have a large background in home automation, and already monitor if my car is parked in the garage or not (here is an example of how I can integrate the status into a live sig on another forum I run: http://www.marstracker.com/homeseer/....php?show=true ) I started wondering, how hard would it be to interface the serial port through the Car PC software so I can control a device that has some outputs, simulating pushing the garage door opener button on the remote in my car?
    I could have the car automatically open the door once it detects the WiFi signal at my house, and maybe add a nice button in one of the common software packages used here to interface the touch screens. Has anyone done something like this before? I am also thinking about maybe interfacing the trunk button, just for the cool factor.
    I am working on something similar. The concept is simple. When in Wi-Fi range I run a client server application on my server at home. Client in the car server on the server (obviously). An SSL tunnel gets established and trough a simple protocol the server then listens to commands like "open door" "turn on lights" etc. The server receives the message and then uses X10 devices connected to its serial port to perform the actions. Works quite well
    Migrane.
    ... you don't need eyes to see ... you need vision !!!
  3. #13
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    With the inputs Phidgets kits have!!! It is very simple..
  4. #14
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Several relay boards are already available.... but anyone in home automation would know that
    TruckinMP3
    Read the FAQ!
  5. #15
    Central NY
    yep I do, I have several, I am more interested in the interfacing with the Car PC interface than anything else, I figured I couldn't be the first one to do this so might as well ask around.
  6. #16
    Aug 2004
    Melbourne, Australia
    i was considering this the other day, as i have at the moment two garage door openers (two homes atm) not fully understanding how all garage openers work would it be possible to create a universal garage opener in the same way universal remotes work? and have the computer control which settings are used / which frequency etc to open different garages?
    just a thought, it sounded like a cool extra in my head =)
  7. #17
    Jun 2004
    GREECE/Athens
    You can have a phidgets kit connected to each garage door controller...
  8. #18
    Aug 2004
    no damn phidgets!!
  9. #19
    Feb 2004
    San Francisco
    Quote Originally Posted by sagekoala
    many of the fords just have normally open push buttons for trunk release ... perhaps even the 2001 taurus ...
    my 99 has that.
  10. #20
    Central NY
    They do sell universal garage door openers (garage door manufactures tried to stop this device by using the DMCA law a few months ago, but they lost), I was planning on buying one of those and tie in to that one.
  1. Looking for user controlling AC Controls (camaro?)
    By ryanerb in forum Input Devices
    Last Post: 04-20-2004, 01:14 PM
  2. OPUS, ACC, Toyota Sequoia Door System, Fusebox
    By Lattice in forum Power Supplies
    Last Post: 03-08-2004, 12:02 PM
  3. Replace door inserts?
    By SuperMatty in forum Off Topic
    Last Post: 12-01-2002, 11:54 PM
  4. Covering door panels and such...
    By SuperMatty in forum General MP3Car Discussion
    Last Post: 04-13-2002, 06:34 PM
  5. garage door IR unit, relocating doubledin cd changer
    By mr0range in forum General Hardware Discussion
    Last Post: 04-10-2002, 04:01 PM
