Results 1 to 10 of 20
Thread: Controlling garage door ...
    Central NY
    Since I have a large background in home automation, and already monitor if my car is parked in the garage or not (here is an example of how I can integrate the status into a live sig on another forum I run: http://www.marstracker.com/homeseer/....php?show=true ) I started wondering, how hard would it be to interface the serial port through the Car PC software so I can control a device that has some outputs, simulating pushing the garage door opener button on the remote in my car?
    I could have the car automatically open the door once it detects the WiFi signal at my house, and maybe add a nice button in one of the common software packages used here to interface the touch screens. Has anyone done something like this before? I am also thinking about maybe interfacing the trunk button, just for the cool factor.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    If you want to control multiple devices, you'll probably find it easier to work with the parallel port, because that gives you 8 independent IO lines.
    Garage door opener shouldn't be hard. All you need to do is take apart a garage door remote and have it controlled by a transistor or something.
    Trunk button? To pop the trunk? Aren't those generally done with cables? That might be considerably more difficult. A hefty solonoid could pull the latch, but positioning it unobtrusively would probably be hard. On the other hand, if yours is controlled with a button that closes a circuit, then it'd be no different than the garage door opener.
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    Quote Originally Posted by mushin
    many of the fords just have normally open push buttons for trunk release ... perhaps even the 2001 taurus ...
    don't worry i know i usually don't make much sense
    Central NY
    Yep I have a simple push button, eventho solenoids would work pretty well, I use one at home to have my house automatically start my car during weekdays, after I wake up. I guess my main concern is being able to integrate this functionality into the CarPC software (not sure yet what I am going to go with).
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    What's up electron... Hey how exactly did you make that page. It's running homeseer right? I'm very intersted. I know I downloaded a demo of that a while back but then forgot about it. What all do you have interfaced with that?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Central NY
    Yes I am running Homeseer and some other interfaces. Check out http://www.CocoonTech.com , it's a non-profit site dedicate to home automation, home theaters and home security, I use the same user name there, so you can find out what and how I do my stuff without me having to go off topic here
    Oct 2003
    Poland, OH
    Electron, I looked at that site for like 20 minutes. A lot of cool info.. I searched by your name and there are 18 pages of threads. Do you have a link to a thread with your setup so I don't have to breeze through all 18 pages?? Thanks!
    Central NY
    Actually, I don't, I used to have web access enabled to the house, so anyone could log in and browse around, but I shut it down as I was upgrading my hardware, and never reopened it, I will try to reopen it later.
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Someone should design a generic relay board and an interface for the common front ends used here.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    try www.phidgetsusa.com
    I am using some of these kits and sensors for a project in the car...
    In the second screen I will be having a/c controls and a background with the car.. When the headlights/ doors etc are on they will be shown in the background.. Also day/night, dim with a light sensor!!!
  1. Looking for user controlling AC Controls (camaro?)
    By ryanerb in forum Input Devices
    Last Post: 04-20-2004, 02:14 PM
  2. OPUS, ACC, Toyota Sequoia Door System, Fusebox
    By Lattice in forum Power Supplies
    Last Post: 03-08-2004, 01:02 PM
  3. Replace door inserts?
    By SuperMatty in forum Off Topic
    Last Post: 12-02-2002, 12:54 AM
  4. Covering door panels and such...
    By SuperMatty in forum General MP3Car Discussion
    Last Post: 04-13-2002, 07:34 PM
  5. garage door IR unit, relocating doubledin cd changer
    By mr0range in forum General Hardware Discussion
    Last Post: 04-10-2002, 05:01 PM
