Results 1 to 3 of 3
Thread: Jeep Radio
    Jeep Radio
    Hello people, i am robotguy
    I am fairly new to car modding, but not at all new to computers and their modification at all.
    However, i had a question- Does anyone know how to remove the radio on a jeep grand cherokee '96?
    Thanks alot for any help!
    -robotguy
    You should check out the wjjeeps.com site for tons of information (instructions w/ pictures): http://www.wjjeeps.com/jmenu.htm
    Epia M10000, Custom enclosure, Starvision SP-VGAT, Linksys WUSB54G, Delorme Earthmate, Windows XP
    Aug 2003
    Michigan
    ok so the thing with wjjeeps.com is it is for jeeps '99 and after... so my 1998 was a little different. i don't know about your 1996, but what i had to do for my 98 was this:
    take off the molding around the HVAC/seat warmer controls to the right of steering wheel (should snap off fairly easily - no screws just some tabs holding it in)
    take off the molding around the headlight/interior light controls to the left of steering wheel (again, no screws just tabs)
    this should reveal 3 - 4 screws that will quite obviously be attaching the piece of the dash that surrounds the radio - take these out
    take the 4 screws out of the top of that same piece of the dash - again should be obvious which ones
    pull slightly, then undo the tabs remaning in place - the first time i took mine off it took quite a bit of force
    then you will see two bolts holding the radio in place. remove these, slide out radio. all is well that ends well.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
  1. Line In Mute problem with Radio...
    By ShawJohn in forum MediaCar
    Last Post: 08-20-2004, 06:21 AM
  2. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 11:52 PM
  3. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 03:38 PM
  4. FM radio Question
    By thepogcbr900rr in forum General Hardware Discussion
    Last Post: 05-09-2004, 07:27 PM
  5. 1997 Jeep Cherokee - Custom In Dash
    By SeeBQ in forum Show off your project
    Last Post: 11-13-2003, 04:11 PM
