Results 1 to 10 of 19
Thread: noob needs help (what else is new)
    ok, i believe i've got most of the parts i need to assemble an mp3 player, but i'm still having trouble finding software for it, i need something that doesnt require a screen, and will function with just a keypad or a keyboard.
    i have
    motherboard(not sure what brand) onboard sound
    pentium 166MMX processor
    64 megs ram (2x 32)
    ethernet card
    video card (i figured jsut for testing)
    125 power supply
    15 gb harddrive
    windows 95 or 98
    Jul 2004
    Baton Rouge, LA
    what you may just need to do is make it stand-alone pc that opens media player at boot and does not allow you to control it once it's up...set a shuffle on it, and only put music that you like on it... or you could get a intellimouse and set the fwd/back buttons to also control the track and mount the mouse somewhere...
    thanks, if i cant find any other way to control the tracks i'll do that, i'd rather be able to control what song i'm on via keypad entry similar means.
    Jul 2004
    yorkshire england
    hey m8 your doing a VERY similar thing to what i did
    what i have is winamp ( far better to WMP) booting up on startup with a nice little key control plug in that sets it playing where it left off ( like a tape would, if you remember those lol) ( i think it is called key control V4.0)
    so it boots and plays, i have a keyboard attached so that i can skip forward a track ( like a cd player) or back a track by pushing 1 or 3 on keypad. 5 pauses and plays, 0 stops ( all this on the number pad) this can be done with the key control plug in
    i would also recomend u get hold of a copy of 98 lite ( it is MUCH smaller and u dont actually NEED anything but what it takes to boot into winamp do u? so stip it out BIG STYLE take away internet explorer and outlook express nd all that crap) PLUS get the MINIMAL version of winamp you dont even need half the crap that comes with the newer versions you could if you are feeling VERY strict get an old version of winamp
    i had ALL of that in under 65 meg TOTAL and it booted in under 30 seconds from power on to music
    literally the only thing u need on is networking to get files accross ( network neighbourhood should do)
    amd k6-2 450
    64 meg ram
    5 gig hdd
    all in an old bit of metal
    all for under £20
    and now a 500watt inverter for £20
    thats £40 in total
    not too bad for a noob
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    You could go with DOS, MPXplay, a 4x20 character LCD, and an IRman, or something like that. Fast boot times. My dos comp would go from POST to playin' in about 3 seconds. I had an amd k6-2 380 and 128mb ram. I'm sure it will work no prob with your hardware, except maybe sound card. That's a little touchy. You can set it up to network thru dos too. And MPXplay supports soft (atx) shutdown. So you hit a key, saves where it's at in the song, and shuts down. It was a sweet setup.
    Tidder
    Try RevFE
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Right on. Winamp with a keypad plugin is just what the doc ordered. Make a monster playlist of all your songs, and set that to run when the system boots.
    Also, be sure the boot the box one last time connected to a monitor without a mouse hooked up, so that you won't get stuck with that "Windows did not detect a mouse" warning when you boot in the car.
    You might also want to install TweakUI and disable "Run scandisk on bad reboot" so the box isn't trying to scan the drive everytime you shut it down hard, instead of doing the Start>Shutdown dance.
    Incidentally, if you are concerned about the hard drive going south by shutting the system down hard like that, don't be. Windows 98, and especially 98Lite, can take it again and again without a problem whatsoever. I've done it for years, and the drive is now doing active duty in one of my home machines without a single complaint or sign of wear (bad sectors etc).
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Sep 2003
    New Mexico, USA
    Why go Windows? With no screen, just boot to dos. MPXplay already supports navigation with a keypad. No messing with ****ty windows 98. You can get dos to do almost everything your 98 would with no monitor.
    Tidder
    Try RevFE
    Jul 2004
    yorkshire england
    2 points
    1) windows is easier to play with for a newbie much more commonly known to play with ( for networking and the such)
    2) dos is a pain to get hold of
    if he just wants something to work go with what i sed if u want to faff about with dos feel free
    ( windows networking is a god send for that kind of thing all u do is plug in and transfer files, DOS sucks *** at networking)
    amd k6-2 450
    64 meg ram
    5 gig hdd
    all for under £20
    thats £40 in total
    Sep 2003
    New Mexico, USA
    Dos is a pain to get a hold of?! I just used good ol' win 98 and took off the windows, left me with Dos 7.something I think. As far as Dos networking goes, if you know what you're doin' it's really easy. Or, if you know somebody (hint, hint) that knows how to do it, no problems. Once it's set up, it's foolproof man...
    Tidder
    Try RevFE
    Jul 2004
    yorkshire england
    well u see i have XP ( you try and get dos from that, if u can ur a better man than most, cos it aint in it)
    but i see your point, but really if he wants to do it all himself he CANT go rong with windows really can he? but DOS is DEAD easy to rong with
    amd k6-2 450
    64 meg ram
    5 gig hdd
    all for under £20
    thats £40 in total
  1. Best noob case?
    By wongerbonger in forum General Hardware Discussion
    Last Post: 05-24-2004, 02:31 PM
  2. Stupid NOOB question..
    By phatbimmer in forum MediaCar
    Last Post: 05-03-2004, 08:01 PM
  3. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 02:34 AM
  4. Replies: 2
    Last Post: 09-30-2003, 08:47 PM
  5. noob need help?
    By fast-shot in forum General Hardware Discussion
    Last Post: 08-21-2003, 07:05 AM
