Results 1 to 8 of 8
Thread: pc133 compatible with pc100?
    Jul 2004
    Washington DC
    I have a eMachines PC. The Kingston and Crucial configurators say it takes PC100 RAM. However, Newegg.com doesnt carry any pc100, only pc133. Is pc133 backward compatible with pc100?? If the pc133 stick has the same specs as the recommended pc100 (CL=2, 16 x 64, etc), will it work in my intel 810 based mobo??
    I want to order this RAM soon, and I was planning on getting a video card from Newegg.com...
    My first carPC!
    MP3/CD player
    Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
    Soon to actually find its way into the car!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I've never had any problem running 133 at 100
    肚子笑痛了
    S60 Install
    Mar 2004
    Dherynia, Cyprus
    it might work or it might not. some mobos ( like the one i have )to accept the pc133 must have chips on both sides of the ram board.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Sometimes later ram has a higer chip density & uses fewer, bigger ram chips. Sometimes these single sided ram sticks are incompatible with some older motherboards. However, there is no reason any ram cannot work at a slower speed than rated.
    Constant Bitrate sheerdark's Avatar
    Aug 2004
    Fayetteville, Ga - USA
    yeah, I always thought that any ram could be slowed down to speed and put into any other computer - but my new carpc proved me wrong. It had to have PC100 or it would just beep incessantly at power on. I only had 2 sticks of PC100 Ram lying around, so I have only 128 mb in my computer as of now - but it's not too bad. However, just b/c Newegg doesn't have any PC100, doesn't mean that no where else does. You can try compgeeks.com or pricewatch.com. Good Luck!
    May 2003
    Miami, FL
    How many memory slots do you have?
    肚子笑痛了
    S60 Install
    Jul 2004
    Washington DC
    thanks guys!
    I have 2 slots. From the factory there's only one 32MB stick. I believe the chips are only on one side of the 32MB stick. I'm hoping to buy a single 256MB stick.
    According to the configurators, max RAM is 256 in any combination. (1x256, 2x128). Here are the specs of the memory Kingston and Crucial 'guarantee' to work.
    16M x 64 non-ECC 100MHz 168-pin Unbuffered DIMM (SDRAM, 3.3V, CL2)
    Now that I read those specs again, it sounds like this stick is dual sided. I think the 16M x 64 means 16MB chips. So a 256MB stick would have to have 16 chips (8 per side). But if I can find these identical specs on a PC133 stick, I should be OK?? I just need to match the memory chip density as pip said.
    I know I can find memory from other places, but I'm planning to order a video card form Newegg and thought it would save some hassle. But if a big name e-tailer like Newegg only sells PC133, I figured it should be compatible.
    My first carPC!
    MP3/CD player
    Jul 2004
    Washington DC
    I just chatted with the Crucial online help folks. They said max memory is 128mb per slot for a total of 256mb. So it sounds like it only supports single sided chips. 16Mb chip x 8 chips = 128MB per slot.
    I'm just gonna find some pc100 or pc133 with those 'guaranteed' specs and give it a shot.
    Thanks fellas!
    My first carPC!
    MP3/CD player
  1. FS: EPIA M10000 Mobo & 512Mb PC133 SDRAM (Brand-New).
    By buildfromscratc in forum Classified Archive
    Last Post: 09-20-2004, 09:32 AM
  2. is XP backwards compatible with 98/2000?
    By delussional77 in forum General Hardware Discussion
    Last Post: 06-25-2004, 05:30 PM
  3. pc133 memory.
    By samc in forum General Hardware Discussion
    Last Post: 03-01-2003, 09:17 PM
  4. LVDS compatible screens for epia M ?
    By felix99 in forum LCD/Display
    Last Post: 12-29-2002, 08:02 PM
  5. compatible or not
    By wildchild22 in forum LCD/Display
    Last Post: 09-04-2002, 01:07 AM
