Results 1 to 2 of 2
Thread: Serial ports/USB to Serial converters
    I'm still researching for my setup, and this board has been great. Been lurking for a long while, just registered recently.
    I'm looking into OBD II interfaces + iBus integration with a mini-itx PC. My question is, for those that need more than one com port, what is your solution? Do those USB-to-Serial adapters work for you in these applications? Are you using a com card?
    TIA,
    -Ed
    FLAC ppgt94's Avatar
    May 2001
    USA
    I have a Belkin USB-Serial converter I got at Staples and it works fine. I used to use it on my laptop (only had USB) with a serial GPS reciever.
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Need three serial ports on VIA Epia - OK?
    By nxt125 in forum General Hardware Discussion
    Last Post: 01-27-2006, 04:24 PM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  4. USB to serial
    By Sleeka in forum General Hardware Discussion
    Last Post: 12-24-2002, 04:55 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
