Dynamat helps significantly, but it is costly and depending on what you are going to use your stereo system for - just turn it up a bit to get rid of the road noise! No, but it helps A LOT - but is expensive.
Why do you want another battery? Just because? you can run a ground wire back to the front of your car for grounding, but it isn't difficult to drill through a body panel, place a grommet and feed the wire through so you can ground on the frame back there...
If you are concerned about your amps getting the juice - just use a large capacitor.
LinkBack URL
About LinkBacks
