I"M A HUGE NOOBIES TO THIS COMPUTER+CAR THING!!@
Anyway, I need a 2-pos rotary switch to power an ATX motherboard on and off (properly, not just cutting power). El Search-o function-o hasn't turned up anything but my old thread.
Because it's an ATX motherboard, the PWRON jumpers need to be shorted momentarily in order to do this. Just using a rotary switch by itself won't work because it'll keep the circuit closed.
Anyone have any momentary switch circuits that'll work?
Help.
2005 Ford Focus ST
No, premade ones return to center when you turn them, kinda like the ignition in your car. I need a definite *click* when you turn the knob left or right and it needs to stay there. I drew up a schematic using some capacitors, but it didn't quite work.
....So when you turn it, you need a "click" and a momentary pulse, but no spring return? whoa, ok, never seen them before!
2005 Ford Focus ST
I know, that's why I need a circuit that will short the PWRON jumper on the motherboard for 1 second when I turn the switch to either position. I know the switch alone doesn't exist.
My short-lived idea was to have two capacitors; one that would charge while the other discharges for about one second and causes a SCR rectifier to close the circuit for a second. I just couldn't come up with a working prototype.
If you didn't notice your caps lock is on.Originally Posted by Gutter
Installed.
-GPSSecure- - GPS Tracking
I had to make this an on-topic post somehow.Originally Posted by brady
Why dont you use Push button instead???
Here ya go, you need one of these with a rotary switch.
http://www.grainger.com/Grainger/pro...mId=1611601184
This one is actually for AC, but I bought one for my car that's DC. This is all I could find in a 30sec search.
This isn't for a car. This is for a separate project where a rotary switch is mandatory.
