Results 1 to 3 of 3
Thread: Are my cable connections correct?
    FLAC -zip-'s Avatar
    Carputer will be in the trunk
    System Specs:
    PIII 500
    20 GB Hard Drive
    Creative Labs Audigy 2 OEM
    500 Megs Ram
    Lilliput Screen
    Nvidia Ti4200 Vid Card
    DVD/CDR not purchased yet
    BU-303 GPS Mouse
    Opus 220 not out yet
    HU in dash Blaupunkt Monte Carlo CD34 with Aux In
    Is this cable run right?
    To Active hub USB DVD/CD in glove box
    To Active hub - USB keyboard + mouse maybe in glove box
    To Active hub -GPS mouse under dash
    Separate run to trunk - Mic for Voice stuff to sound card
    Separate run to Battery Opus 220
    Separate run VGA to trunk - Lilliput Screen in dash
    Separate USB run to trunk -USB Hard Drive IDE to USB converter (3.5 drive in enclosure) in glove box
    Sound - thanks for the sound card to Aux-in sticky
    Trunk to Glove box - to Hard Drive and DVD one run with Y splitter back to Opus?
    Option not sure how
    Power/standby/resume button - cables to run up to dash (if possible) - no idea how to do this but would be a good emergency and convenience feature.
    I have read that the hard drive should have its own seprate USB run.
    I know that I have 5 metres to play with and could use a USB hub to extend. 5+ meters have to use an active hub, so we are talking power supply. Now where do I plug that into?
    I would like to use the least amount of power and USB cables running back and forth.
    My head hurts after writing this...
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    you might as well include your system specs for the guys that would give the correct answer. Remember you can never provide too much information, well in the forums at least!
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    FLAC -zip-'s Avatar
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  3. Wanna extend your Kiosk 12.1" LCD cable?
    By CDesigns in forum LCD/Display
    Last Post: 05-13-2004, 10:10 PM
  4. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
  5. Cat6 cable -> IDE Cable
    By dan0myte in forum General Hardware Discussion
    Last Post: 08-31-2001, 09:29 AM
