Results 1 to 7 of 7
Thread: Cables runs electrical connections Noob with no electrical experience
    FLAC -zip-'s Avatar
    Ontario/Canada
    I will be getting an Opus in the trunk and running power and USB from front to back.
    I need to power a DVD/CD, Power USB Hub, IDE to USB converter.
    How do you connect a powered USB hub to car power? It comes with a 5v-120v power adapter (i think). Do you just cut the wire on the 5v side of the adapter and run it to a 5v molex cable from the motherboards power? If so the power adapter has 2 wires and the 5v molex has 4?
    I read a post on this board to run power up to the front of the car from the trunk you cut a 5V and 12V extension molex plug from the motherboard then run what ever length you need between the now cut molex plugs reconnect the plugs at the new length.
    Then you have a 5V and 12V plug up front to connect stuff.
    Is this correct?
    FLAC ppgt94's Avatar
    May 2001
    USA
    Is this correct?
    Yes. This is EXACTLY what I have done. I power a 4-port USB hub, slimline dvd drive, and my Xenarc LCD off the Opus.
    FLAC -zip-'s Avatar
    Ontario/Canada
    How did you connect the powered USB hub, DVD etc on the device end? to the molex connector?
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by -zip-
    Just to clarify for you, the 4 pins on the standard molex connector carry both 5V and 12V, and two grounds. The red wire carries 5V, the yellow 12V.
    May 2001
    USA
    The dvd drive used a floppy power connecter so I clipped one of those off an old power supply I had and used that. Itsimply connected it to the end of the 5v wire I ran up from the Opus. The USB hub came with a power adapter. I clipped the power adapter plug off and connected the 5v to that as well. For that ground I just connected a wire to some metal inside the dash with a screw.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks guys that really helps. It is getting clearer now.
    the colors help a lot and I did not know both were on the same connector.
    With the USB hub do you have to cut the wire before that brick thing or can you cut the wire after and just run the 5v into the hub?
    Also the ground - you ran the 5v wire into the adapter one wire then grounded the molex? sorry im such a noob.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by ppgt94
    Did you ground your +5V regulated HUB to the chassis of the car!!! This shoulndn't be right!!!!!!
