Results 1 to 9 of 9
Thread: testing the pc inside
    Springfield, IL
    how do you test your carpc at your house, so you don't have to install everything in your car?? im using a opus
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Use a regular PSU. Build your computer like you would a regular desktop. If you don't have a (extra) PSU, you could get you an AC-DC converter to run the OPUS. It will change 110VAC to 12VDC.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Springfield, IL
    thanks, you mean one of those converters that you can find at radio shack or whatever and just cut the adapter off??
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    That's the right idea, though most AC-DC bricks won't supply anywhere near the required current. I distinctly remember another thread on the exact same topic, with some links to ones that would work. Try searching.
    Low Bitrate modUlarBeing's Avatar
    Aug 2004
    yes, radioshack has them. the biggest one they have is 10amp, they might have something you can order from radioshack unlimited that is bigger if you need it.
    http://www.radioshack.com/product.as...ct%5Fid=22-506
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    My install is in a briefcase so I can move it between cars quickly. I pull the PC set it on my desk and hookup a desktop PS and add a nic if I need to move files or update software.
    TruckinMP3
    Read the FAQ!
    Variable Bitrate blurp's Avatar
    Sep 2003
    Hampshire, TN
    The easiest way to get a load of 12V power in your house is to use an old AT psu. A 250W AT psu should output 10A on the 12V side.
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    good idea...i just use a 10 amp radioshack AC/DC convertor but i'll keep that in mind in case i kill it (which im bound to)
    CarPC install is starting to come along again...
    Sep 2003
    Hampshire, TN
    Yep, I've actually run a 1,000,000 candle power spotlight off of one. It has a 100W halogen bulb in it.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 05:27 PM
  2. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  3. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 05:30 AM
