Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: BMW E46 Owners with DSP systems and no HU
    How did you wire it? I've been told by a few that it will be a pain in the *** to use any existing equipment because of the custom speaker and amp wiring...most suggest replacing all speakers, running new wire, and buying an amp.
    I'd like to eventually replace my HU with a carputer but before I do so I want to make sure theres not an easier way to use the existing speakers...anyone have a wiring schematic or information on this?
    TIA,
    -Ed
    Oops, posted in wrong forum. Mods, please move to newbie.
    Jul 2004
    for 2002+ cars you could use the OEM auxilary input, but that won't help you...
    I would ask this question to the audio experts at e46fanatics.com
    Thanks, I'll check it out over there.
    Jun 2004
    AZ
    edrock, did you find this answer? I am in the middle of my project on a 2004 330i and have not started the audio side yet. I want to hear the sound quality with my carpc first before I tear out all OEM sound. Let me know if you find somthing and I will let you know as well.
    Banned
    Feb 2004
    2003 E46 here
    I did not replace my stock headunit, but I can tell you that you're probably better off just mounting the screen to where the sunglass/ashtray area is. Unless you want to replace every audio component in your car it's probably better to just use AUX IN on the stock headunit. BTW the sound quality on mine is pretty good. Sounds just as good as the business CD player quality.
    Heres the best I've found:
    http://bimmer.roadfly.org/bmw/forums...1433274&page=2
    The link above has tons of info and pics...the following has been extracted from the link above:
    Grey ½ of connector
    Pin # 13 / Tweeter Rear Right door + * Yellow Pin # 21 / Tweeter Rear Right door - *Blue / yellow
    Pin # 12 / Tweeter Front Right - Blue / Brown Pin #20 / no connection
    Pin # 11 / Tweeter Front Right + Blue / black Pin #19 / no connection
    Pin # 10 / Switched +12v remote turn on White Pin #18 / no connection
    Pin # 9 / Head unit output Front Right + Blue / red Pin #17 / Head unit output Front Right - Brown / orange
    Pin # 8 / Head unit output Rear Right + Blue / black Pin #16 / Head unit output Rear Right - Brown / orange
    Pin # 7 / no connection Pin #15 / no connection
    Pin # 6 / no connection Pin #14 / no connection
    Pin # 5 / +12v factory amp +12v supply *Red / green
    Pin # 4 / Woofer Front Left +Blue / white
    Pin # 3 / Woofer Front Left -Blue / brown
    Pin # 2 / Woofer Rear Left +Yellow
    Pin # 1 / Woofer Rear Left -Brown
    Black ½ of connector
    Pin # 34 / Tweeter Front Left - Yellow / brown Pin # 42 / Mid Front Right door + *Green
    Pin # 33 / Tweeter Front Left + Yellow / red Pin #41 / Mid Front Right door - *Blue / green
    Pin # 32 / Tweeter Rear left door - * Yellow / brown Pin #40 / Mid Front left door + *White
    Pin # 31 / Tweeter Rear Left door + * Yellow / black Pin #39 / Mid Front left door - *Blue / white
    Pin # 30 / Head output Front left - Brown / orange Pin #38 / Head output Front Left + Yellow / red
    Pin # 29 / Head output Rear Left - Brown / orange Pin #37 / Head output Rear Left + Yellow / black
    Pin # 28 / no connection Pin #36 / no connection
    Pin # 27 / no connection Pin #35 / no connection
    Pin # 26 / DC ground factory ampBrown
    Pin # 25 / Woofer Rear Right +Blue
    Pin # 24 / Woofer Rear Right -Brown
    Pin # 23 / Woofer Front Right +Blue / Red
    Pin # 22 / Woofer Front Right -Blue / Brown
    Jun 2004
    AZ
    great link edrock!
    Thanks, I've found it really handy. That wiring diagram and the pics are awesome.
