Results 1 to 9 of 9
Thread: Trying to kill two birds with one stone - help!
    Newbie desiz's Avatar
    Jun 2004
    California
    Was almost about to start buying parts for my carputer, till i realized my home gaming system required an upgrade. So am trying to kill two birds with one stone by trying to use my current desktop for my car-pc.
    I just need to know if what i am planning will work:-
    its a dell dimen 4400, atx with a 170W power supply.
    now i plan on probably getting the opus 150W DCDC and using that to power just the motherboard (1.6ghz 400fsb socket n),on-board sound, a 64mb agp geforce2, a 40gig wd 7200rpm drive and a usb gps. that's it.
    Motherboard details i could get are that its a Planar motherboard, made for dell based on the intel D865GBFL specifications
    Will the 150W opus be enough ?, I'll have to put the barebone motherboard since no case will fit (04 350z). So will there be heat issues ?
    All advice/suggestions appreciated!
    thanks!
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Based on my own experience, I would say the OPUS will do just fine.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It will probably work, but you must be carefull with the power connector to the mobo. Dell stuffs sometime are not standard meaning standard power supply may not work with Dell mobo.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jun 2004
    California
    whew... found this on ebay, and a little note below that says :-
    NEW Power Supply Adapter for Dell Motherboards
    Lets you use your standard ATX power supply with most Dell boards!
    Known exceptions:
    Pentium 4 Dell Models that do not require a power supply adapter:
    Dell Dimension 4300
    Dell Dimension 4400 <----- yea!!!
    Dell Dimension 8200
    so will 150W be enough power for m/b+512mbram+agp gefroce2+onboardsound+usb gps+lilliput screen ?
    Oct 2004
    Los Angeles, CA
    I dunno how much the lilliput draws, but sounds like it should be enough.
    Carputer - 100% Complete!
    1993 Mazda MX-6 - 100% Totalled!
    Bought new 1995 Saab 900SE Turbo - Need new Micro ATX Case (Simple 101 case maybe?)
    Jun 2004
    Central California
    150W should be enough. You can power the usb gps and lilliput with an external power supply controlled by a relay.
    Btw, it's the heat build up that you need to worry about.
    Constant Bitrate KaiTech's Avatar
    Quote Originally Posted by desiz
    thanks!
    I would be carefull... especially with that GeForce...
    I'll spout simplistic opinions for hours on end.
    Ridicule anyone who disagrees with me,
    and generally foster divisiveness,
    cynicism and lower level of public dialog!
    Jun 2004
    California
    edit: i guess u guys mean the heat problem , i thought power ...
    i plan on putting an extra fan if there is a heat problem.... though i don't think it will be on for more than an hour at a stretch... unless i go on a road trip
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    hmm.
    Here's my input: power is just fine, heat = kinda of an issue.. Re-design the case for better airflow maybe add a few fans.
    Good luck on your project !
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  1. HOLY CRAP.....this is insane
    By cadence117 in forum Off Topic
    Last Post: 06-17-2008, 07:37 PM
  2. Will a UPS kill my inverter?
    By arsalan_altaf in forum Power Supplies
    Last Post: 02-14-2004, 08:00 PM
  3. Will this kill my battery?
    By ppgt94 in forum Power Supplies
    Last Post: 12-04-2002, 05:19 PM
  4. Kill Cigarette Lighter with ignition off
    By wallachee in forum Power Supplies
    Last Post: 02-05-2002, 06:29 PM
  5. Kill two birds with one stone?
    By steve671 in forum General Hardware Discussion
    Last Post: 12-12-2001, 06:43 AM
