Results 1 to 10 of 16
Thread: Tank Circuits
    Constant Bitrate LeoTheHamster's Avatar
    Jul 2004
    Kings Lynn, Norfolk, UK
    Tank Circuits
    Maybe I'm being a bit stupid here, but couldn't the whole tank circuit parafinalia be bypassed by using a switch to turn the pc on after you've started the car?
    Leo
    http://www.talkaudio.co.uk
    A million people can't be wrong, right?
    Well... unless they're all from the red states...
    Raw Wave
    Jun 2003
    What if you need to refuel and need to crank the car again? that mean shuttingdown before refuel and restarting again.
    ...or what if the car stalled? No way Im shuttingdown
    Your idea will work, but not with us here because we are lazy and impatient
    Jul 2004
    Ah, the advantages of having the pc as a slave audio system
    I think I'll save myself a wodge of cash and use a switch
    Leo
    Oct 2004
    What are u guys talking about? I dont understand!
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Signature: [==||========] 20% complete
    Oct 2004
    I did, and got 500 results. looked at some of them. and still dont know whats going on!
    I understand from this that its possible to turn on the computer by starting the car. and that can be done by doing something to the Circuit. LeoTheHamster is saying why bother and screw around with the sercet. Just connect a simple ON and OFF button to the computer.
    OKAY? but then....
    If the computer has its own switch, and its own switch going to turn it on and off, what this has got to do with anything? (Maybe that way the computer wont get electricity?)
    See? I'm lost. I dont know whats goin on. I'm a n00b. and thats why I'm at this section of the forum
    Oct 2003
    A tank circuit is simply a device that is inserted into the power feed to the car computer.
    Ordinairily you connect the computer PSU to the car battery, if you take an opus PSU for example this has the ability to survive crank, i.e. when you crank and the voltage dips, the opus doesn't mind it carries on as normal.
    Other PSU's however, do mind. When you crank and the voltage dips, the PSU switches off and the computer reboots, there is where the tank circuit comes in, its like a separate "tank" of voltage.
    This separate tank of voltage comes in the form of a small seconday battery, it is isolated from the main battery for the duration of the crank and is used solely for the purpose of smoothing out the voltage dip.
    The tank can be isolated from the main battery by the use of a diode or a relay, which are the more popular methods.
    The diode approach only allows the tank battery to recieve a charge from the existing battery and alternator and will prevent the reverse flow when main battery is called upon to crank.
    The relay approach physically disconnects the supply from the main battery during crank and reconnects after crank is complete
    Both circuits are available here and are well discussed for pro's and con's of each.
    Having a switch to turn the computer on and off after crank will not solve the voltage dip problem upon crank.
    It is the near unanimous (spelling) opinion that the opus is the tool for job, it is expensive but it is better than buying twice, i.e. like what I am going to have to do.
    I bought a mains inverter and have a sepearte switch, then I discovered this board and am now saving for an opus, SO much easier and, I wouldn't mind some leg room back for my passengers
    if you can't find time to do it right, when are you gonna find time to do it over.
    Oct 2004
    Sounds like a very long story I dont feel like going through nor spending money over it. So if I want the computer to run while driving... will I have to go through all of this?
    Oct 2003
    Quote Originally Posted by Fear Effect
    uh?
    I was explaining what a tank circuit was, it's not necessarily a process that you HAVE to go through, more of what a tank circuit IS and the ways that it can be implemented.
    To drive with the computer on it needs to work (obviously) and the important issue which relates to this thread is that it would be desirable, but not imperative that it works throughout the crank duration.
    You have 2 realistic options for this, opus or tank circuit.
    If you have faith in your alternator and standard battery then you can get away with not having a tank circuit, I don't and I don't have an opus either but I realise that my 2 truck batteries are not the perfect solution and am going for a better one i.e. the opus
    Hope that clarifies a bit
    Cheers
    May 2002
    I use a laptop wired directly to teh fuse box with an auto/air adapter ...has 160 gigs of space in it...sits in a port repicator under the front seat. has all the output connections a desktop would have and I turn the car off I throw it in pause with the remote and it will run for 2 hours that way...start the car and hit pause again exactly where I left off. grab the spare powersupply from the glove box undock the laptop throw a cable from the audio out to an input on a stereo anywhere even a tv..and instant party tunes. audio, media, GPS and no fuss.
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Tank Circuit
    By digglerd in forum Power Supplies
    Last Post: 07-28-2004, 03:17 AM
  3. Problem with tank battery - any good Plan B?
    By Mastiff in forum Power Supplies
    Last Post: 06-14-2004, 10:10 PM
  4. Tanks Circuits
    By falconey in forum Power Supplies
    Last Post: 05-10-2004, 11:52 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
