Results 1 to 9 of 9
Thread: Carputer Power up help
    Oct 2004
    I have a carputer built
    1.8ghz p4
    80gb hdd
    512mb ram
    audigy 2 zs
    32mb vid card
    7" touchscreen
    usb hub
    now i read all these threads on powering it up with the car, and how if you start the car it will reboot, so you need some special type of power supply like the opus. i have a normal 400watt psu, but you guys say that wont do, i was looking at the opus, and i dont see how i should hook that up to the car battery, and i have searched all over the forums, and the circuitry is a bit too much, can anyone help a newbie, thanks a lot guys, if you have aim/aol, IM me at "ECA Andrew" thanks.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Well you didn't search hard enought, but anyway here is your answer.
    Do you know how to hookup a car amplifier for power? The Opus hookup just like that.
    3 wires: GROUND, POWER (battery), REMOTE/IGN/ACC (remote turn on from HU. In this case signal from the key)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Oct 2004
    thanks, im familiar with a car amp, how would i hook up a car amp and the opus to the battery, can you do both, thanks for the help.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Do the opus just like the AMP. Its the same process just do it twice. One for the AMP one for the CarPC. 3 wires each hot, ground, switched.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Sep 2003
    Beach City, Socal
    Basically this is what I did.
    Run one big wire (2GA or 4GA) from the battery to the back of the car (where the amp and Carputer will be) and put it at the distribution block. From the block one wire to the amp and another to the Opus. GROUND for amp and Opus doesn't have to be at the same spot unless they close to each other. Otherwise, make it as short as possible and preferable bigger wire than the power wire.
    Oct 2004
    which PSU do you recommend for a P4 2.8 desktop for my car? I heard opus makes good ones but will the 150 opus do? And do i need an inverter also?
    Oct 2004
    to be more specific... i have a dell dimension 4600 and i was thinking i should go with the 150w opus DC/DC. Is this sufficient enough? do i need anything else to power it? does the opus 150w sold on this site come with all the wires and etc.. i need to hook it up to my car?
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The Opus 150W should be perfectly fine.
    They do not come with all the wires to hook it up to the battery, only about 6" of cable. Get yourself something like an amp wiring kit for ~$25 from Walmart etc.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Hey you're on MP3car? This is really crazy because I know you and this is like an international site. Msg me on AIM at Gr4yscale, I'll give you some info. You WERE hosting heshers site i think, right?
    CarPC install is starting to come along again...
  1. powering the carputer on??
    By boomboom in forum General MP3Car Discussion
    Last Post: 07-18-2004, 08:32 PM
  2. Opus 90w Power Action
    By EBoundEE in forum Power Supplies
    Last Post: 03-10-2004, 10:11 PM
  3. starting my first carputer project, have some questions
    By ssa_whiskey in forum General Hardware Discussion
    Last Post: 02-24-2004, 03:43 PM
  4. Full Size Carputer..How to power it?
    By Otha in forum Power Supplies
    Last Post: 02-16-2004, 10:59 AM
  5. Replies: 16
    Last Post: 11-13-2003, 02:02 PM
