Ok, the 1.0GHz is going to be more than enough for what you need. Quite a few people use 600-733MHz processors. However, if you can, underclock the 1.0GHz. It should stay very cool. As for RAM, it depends on the size of the case as to what you can use. Check on the case specs, it should tell you there. The best thing you could do is buy incredibly fast ram with your underclocked FSB, this will cause the ram to run slower, but will, again, keep things cool. Again, for PCI, only some cases have to room for a pci card, check the case specs again. The power supply that comes with these cases is not regulated. Because you dont have the AC/DC inverter. You will want an OPUS, or some other power solution for a CarPC. I would reccoment the OPUS because its n00bproof. Easy to use and install, some of the others require more technical knowledge, and some of the other power suppies do not regulate voltage on the +12v. Not a good thing. I dont know about the PlayStation screen.
LinkBack URL
About LinkBacks
. I'm an absolute noob when it comes to carputer. Also one more Q, who was that who custom modified his PSone lcd screen? It was more of an advanced modding but I can handle it.
