Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: using a laptop
    Low Bitrate PatrickB's Avatar
    Oct 2004
    using a laptop
    whats everyones thoughts about justing using a laptop that has a bad screen? my company just gives away laptops that are no longer under warranty if something breaks. even if its a 30 dollar keyboard. i happen to have a 1ghz ibm laptop with a bad screen just 1 usb out but it does have a DVD player.
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Plug an external monitor into it (like a Xenarc) and it'll be fully functional again. Hard to mount a laptop in a car so you can use its screen anyways.
    Oct 2004
    Quote Originally Posted by Change
    well i understand that part.. i mean is it just as good as using a cheap computer. i can't really upgrade the sound car etc. i would have to use a USB hub etc. can u still use something like opus to put it in sleep mode etc.
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Opus is designed for ITX or ATX boards. Laptops are neither of these. So, no, it won't work. You can re-use the RAM, HDD, DVD-ROM in a carputer project though. That will easily save quite a bit of money...Feel like sending one of those laptops my way?
    Quick! To the Popemobile!
    Variable Bitrate nottastocker's Avatar
    Jun 2003
    Shenandoah, VA
    ill take one, ill pay the shipping
    Oct 2004
    Quote Originally Posted by BiohazrD
    lol if i did that i may as well just use one of the blue million decomped 1ghz machines. they are already small form factor and 512 megs of ram. i just thought laptop might serve better w/ the HD etc.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Get a laptop car power supply and use an ITPS wired to the power button on the laptop to turn it on/off. The onboard sound will probably be noisy so I'd get an Audigy NX USB sound card.
    Oct 2004
    Quote Originally Posted by pip
    can u throw out some liksfor the laptop car ps and itps?
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Car power adapter (though if you do a search for 'notebook dc power supply' I'm sure you'll find cheaper).
    ITPS
    Oct 2004
    ITPS
    thank you
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  3. Shutdown/Startup Controller for laptop
    By JoyRidun in forum General Hardware Discussion
    Last Post: 07-01-2004, 07:08 PM
  4. Simulating laptop functions
    By corsamel in forum Software & Software Development
    Last Post: 05-20-2004, 03:41 PM
  5. Replies: 11
    Last Post: 12-02-2003, 08:29 AM
