err isnt that on the USB line? Not the power?
Good god! 15A fuse is way too big. The Lilliput draws somewhere between 0.5 and 1 amp.Originally Posted by -zip-
nope, maximum the usb can put out is .5amps
15 amps at 12v is 180w if it drew this much power you couldnt connect it to your power supply now could you...![]()
Signature: [==||========] 20% complete
Yes, what NIC said. Look at the cigarette lighter adapter. It should have a fuse already in there. I would recommend a 1 A. or 1.5 A. fuse max. Same goes for the USB hub.
System:
Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
Good thing I checked with you guys before the install![]()
Sound StageEclipse|MTX|Infinity
Why do you want to put seperate fuses on everything, why not just put one fuse close to the battery before the opus?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
where is the gray wire, I don't see it on the Lil, am I missing something?
Basically to protect the Opus and/or anything else. If anything fries (shorts) after the Opus, it could take out the Opus as well. Not to mention protecting the device itself from further damage by letting it cook @ higher amperage. -zip- also mentions wire runs of 15 ft. Anything can happen to a wire in 15 ft. Automobiles have been known to burn up in flames due to electrical shorts.Originally Posted by Quattro-A4
System:
Don't forget the "egg" īlinline with your Lilliput. The Xenarcs are voltage tolerant, but the Lilliputs seem to need the extra line protection.
o/______\o
(oo_OO_oo)
[]o-----------o[]
'94 320i
I was hopeing not to use the "egg" it is very finacky. Is it possible just to run the wire since the Opus will regulate the 12V line?
