Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Diagram inside - Is this correct on how to hook up power USB etc with an Opus?
    FLAC -zip-'s Avatar
    Ontario/Canada
    The 2 wires from the adapter that comes with a USB hub and the lilliput power hookup I want to confirm.
    Sound Stage
    Eclipse|MTX|Infinity
    Sep 2003
    Northeast Ohio
    Looks good to me. Thats how I have mine wired. Been running since April '04.
    edit:
    I would also recommend using an in-line fuse at least on the monitor.
    System:
    Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
    Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
    Constant Bitrate Avalerion's Avatar
    Jun 2004
    Hamilton, NJ
    Don't you have to run a ground line to the lilliput?
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    That would be the gray one ...
    Jun 2004
    Hamilton, NJ
    What gray one?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Fuse line on Lilliput.. got it thanks for the info. 15 A fuse?
    Sound Stage
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    What case are you using? Most of the Mini-ITX cases have a built in 60w PSU. If you are using one of these. I would reccomend the power supply from CarNetix. It already has output for USB and a 12v touchscreen. Plus, its cheaper, as it is simply a voltage regulator that works in conjunction with the current PSU.
    Quick! To the Popemobile!
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks Bio,
    I am running a Micro ATX board with a power hungry AMD processor
    I dont think with my set up 60w would be enough or even a 90w. I am also waiting to see if Opus will solve the USB "always on" issue with the new PSU.
    Sound Stage
    Oct 2004
    Hey
    So if someone could find a case with a 90W or 150W power supply, does that mean we don't need the opus? Also from the wiring diagram above how would you get power to a cd-rw/dvd-rom drive? Thanks.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Hi Legend,
    You need a DC-DC power supply or an Inverter. The power supply has to survive crank of the engine. Also Opus uses a regulated 12V line so it's much better for your Screen and it has an auto shut down, the ON/OFF lead is monitored to start the PC and to implement a safe shutdown procedure.
    As far as the CD/DVD do you see the free molex connector in my drawing?
    Sound Stage
  1. 5V on USB header question w/ Opus 150W
    By beckkl in forum Power Supplies
    Last Post: 10-25-2004, 10:18 PM
  2. Can't get my OPUS to power up PC
    By jayfish in forum Power Supplies
    Last Post: 08-04-2004, 02:30 PM
  3. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  4. Opus 90w Power Action
    By EBoundEE in forum Power Supplies
    Last Post: 03-10-2004, 10:11 PM
  5. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
