Results 1 to 7 of 7
Thread: a few questions (PS, AMP, etc)
    Variable Bitrate fuctup's Avatar
    Nov 2004
    Minneapolis
    i recently decided i cant afford those cool in dash dvd nav systems... but i can put a PC in my car for a few hun.. with tons of mp3s and wireless net. searching brought me across this site - nice site. anyways-
    original plan- throw a 1ghz dell desktop i have sitting around in my trunk, small lcd monitor up front, wire sound card to a amp. power the pc iith a inverter i have. research gave me new ideas.
    new plan-
    microATX board
    custom case most likely, thinkin plexi cause i got some layin around
    snap on style 200w DC-DC power supply with itps to regulate
    2.5" 5400rpm 30gb HD
    1.6ghz AMD
    1x 128mb PC2100
    pci sound card
    PCI wifi (or maybe usb/pcmcia)
    i think a slim DVD drive(optical drive is undecided)
    and i plan on looking into gps antennas/software. i plan on getting a small but quality 4ch amp and component speakers for the car audio.
    if your still reading thank you and heres my questions:
    whats the best priced and quality 7" VGA LCD? (touchscreen or not)
    i was planning on using PW200M DC DC Power supply and a ITPS, from what i understand i can wire this strait to my car battery. would this work good ?
    one thing i am worried about, running a sound cards outputs into a car amps inputs - will this sound good? will there be engine noise? will i need line driver? the sound part i think is gona be cool, cause i like the dsp's ive had on my PCs.
    thanks for any help and suggestions, the power supply part is what i am most concerned about, and im trying to keep it under $100.
    Newbie jontheinstaller's Avatar
    Oct 2004
    riverside ca
    check out the liliput 7 inch vga touch screen. you can buy it on mp3cars websight costs about 280 with shipping
    Jon @louderthanlife.net
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by fuctup
    your options are really lilliput or xenarc for info on these
    no itps is crap, wont survive crank, and may not work with the car off
    use a decent soundcard, lots of people use creative usb soundcards because they can go away from the computer and close to the amp, this helps reduce the possiblity of interferance/noise
    Signature: [==||========] 20% complete
    Nov 2004
    Minneapolis
    thanks for the info.
    ive never used a usb sound device, do people have problems alot with PCI? i already have my sights set on a turtle beach pci card, and it would be less mess.
    what power supply would you recommend for the system im putting together? i know its not as low power as itx systems, but its cheap and fast. with cheap expansion possibilities. i figure 150w up would be safe. maybe less?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    now that i read your post again there is no way that system would work with the itps, the largest amount of power the itps can regulate is 60w, so even if u use a 200w snap in your computer will still only get 60w
    read up on posts about the 150w opus, i would assume it would be fine for this setup, how much power does the amd cpu draw?
    Nov 2004
    Minneapolis
    damn, that sucks cause that power supply is like $200...
    as for the cpu draw, if you mean watts, im not sure.. its a 1.6Ghz amd duron 1.5v applebred core.
    Jun 2004
    The North, Manchester
    Surely ITPS wouldhandlean ATX machine thats designed for low Wattage draw?? Laptop Hard Disks, low watt Cd Drives etc etc??
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 02:41 AM
  2. genral amp / 12v ps question
    By rb_selectblend in forum General Hardware Discussion
    Last Post: 10-29-2004, 08:01 PM
  3. Amp Questions
    By toe2003 in forum Newbie
    Last Post: 10-26-2004, 07:52 AM
  4. Is 8 gauge wire heavy enough? Amp + PS
    By mhorton in forum Power Supplies
    Last Post: 05-23-2004, 11:47 AM
  5. Building ATX DC-DC PS. Got questions...
    By Pred8tr in forum Power Supplies
    Last Post: 10-31-2002, 03:27 AM
