Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: a few (newb) questions, as far as wiring and power, etc
  1. #11
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by Bailey
    Can you please make this more clear? Leave the 12V car lighter plug in tact (including the "egg") and extend it to the PSU, then make my own molex plug using the + as 12v [yellow molex] and - as ground [black molex]. Did I get that right?
    You are correct however I have read posts stating that the 'egg' tends to burn out or die. If you don't want to buy anything then I would cut between the plug (to the screen) and the egg and wire as you described above.
    Since I did not want to cut the original powersupply, I went to RadioShack and bought the following:
    Adaptaplug N - $4.99
    6 Ft. Adaptaplug Extension Cable - $5.49 This cable has two female connectors for the adaptaplugs. I cut it in half and used on side for the screen and the other for my SB Extigy.
    For best results get a Molex plug so you can simply plug it up to your power supply. You can also find them at RadioShack but I'm not having any luck finding them on the website. Don't forget to look up the Lilliput Auto Turn-on mod for the Lilliput.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  2. #12
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    Quote Originally Posted by d_sellers1
    I checked that out, but it is wayy too hard for me. I'd rather turn my monitor on manually than fry it with some silly mod.
  3. #13
    Mar 2002
    Austin, Texas
    I'm actually going to have a friend supervise me/assist me/do it for me.... (pick one). If you can get someone to do the soldering for you, I would think that would be a good improvment to your system. You computer starts up and the screen will also turn on.
    Derek
  1. Wiring Power Switch With Inverter
    By Jiroe in forum Power Supplies
    Last Post: 10-29-2004, 06:27 PM
  2. Some wiring questions??
    By jnusaira in forum Newbie
    Last Post: 10-26-2004, 11:33 PM
  3. ITPS and PW-70a wiring pics
    By cpjolicoeur in forum Power Supplies
    Last Post: 05-19-2004, 01:34 PM
  4. Wiring from battery and switch questions
    By bombboyer in forum Power Supplies
    Last Post: 02-06-2004, 07:17 AM
  5. keypower wiring questions!
    By AndyM in forum Power Supplies
    Last Post: 08-21-2001, 05:55 PM
