Results 1 to 10 of 16
Thread: opus power supplies?
    Oct 2004
    What is the difference between OPUS 90-watt DC-DC Power Supply and
    OPUS 150 watt DC-DC power Supply
    besides the watage, the pictures look very different or is the 150watt just in a metal case making it look alot different?
    Aug 1999
    Washington D.C.
    They just look different, I don't know why they were designed that way. They are the same other then the obvious wattage difference and also some of the jumper selectable settings are different.
    Oct 2004
    thank you for clearing that up for me!
    Banned
    Feb 2004
    150watt OPUS has a fan and the 90watt doesn't. At least on my friends 150.
    Newbie harrisonpowers's Avatar
    Nov 2004
    Westchester, NY
    I wouldn't need a battery upgrade to run the 150watt opus would I? 04 WRX here, factory stereo.
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by harrisonpowers
    no.
    Installed.
    -GPSSecure- - GPS Tracking
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    150w = A * 12v
    A = ~14 amps
    90w = A * 12v
    A = ~8 amps
    A car battery is somewhere in the range of 250 cold cranking amps. That gets larger depending on engine size. Assuming 250 amps, you have 2500w of power to mess with. I would only worry about a second battery/larger battery when approaching this amount with an aftermarket system.
    Quick! To the Popemobile!
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    if you draw more power than your alternator outputs you will end up draining your battery, i know my alternator only puts out 60-70A (yes its crap) and some of its gonna get used by the car so 2500w is somewhat unrealistic
    Signature: [==||========] 20% complete
    Constant Bitrate LeoTheHamster's Avatar
    Jul 2004
    Kings Lynn, Norfolk, UK
    Quote Originally Posted by Nic
    Split charge
    Leo
    http://www.talkaudio.co.uk
    A million people can't be wrong, right?
    Well... unless they're all from the red states...
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    ahh what?
  1. WTB: Dc-Dc power Supplies (Opus or PW60-90 and ITPS)
    By djhustla in forum Classified Archive
    Last Post: 07-02-2004, 11:29 AM
  2. Power lead for the OPUS
    By Ripsurf in forum Power Supplies
    Last Post: 06-17-2004, 08:52 AM
  3. Opus is the only power supply that...
    By sunkistzzang in forum Power Supplies
    Last Post: 05-19-2004, 08:52 AM
  4. xBox Power Supplies
    By crosseye in forum Power Supplies
    Last Post: 05-07-2004, 01:32 AM
  5. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
