Results 1 to 10 of 14
Thread: What should I use to power my mc before install
    Nov 2004
    What should I use to power my mobo before install
    I will be getting my entire system tomorrow and I'd like to set it all up in my house rather than the confines of my car. I ordered a opus and that's all I'll have for a psu so I was wondering how I should power the pc up tomorrow. I have a jump box if that would work or should I just borrow an atx psu for a day and use that.
    Also in a different post i asked about installing a button to turn on my pc since I am not using a case I won't have a power button. Is this somehting I can get from radio shack or can I make one what do you guys think. Thanks.
    Constant Bitrate Vorex's Avatar
    Nov 2004
    Lake Worth, FL
    The opus has a header to plug into your mobo's header where the power button would go, so the opus can turn the system on
    - Vorex Out
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Vorex
    I think he's asking how to run the opus in his house without the car.
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    I will be using a spare car battery, charging with a car battery charger. I don't know how I will turn the system on yet, maybe someone can give us some ideas.
    Jul 2004
    Berkeley, CA
    Find the pins on the motherboard for power on (PWR usually) and short them. That will turn on the motherboard.
    Jul 2004
    Atlanta, GA
    I used a jump start device. It has cables to jump a dead battery and also a cigarette lighter adapter. Just charge it up with 110v ac and you're good to go.
    Nov 2004
    NYC
    Quote Originally Posted by 0l33l
    Great I was wondering if it needed a constant feed
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Bailey
    ATX are momentary. If you short it for 4 seconds while the motherboard is on then it will shut down if the OS isn't cooperating. You can also short the reset pins. Paperclips do wonders
    Newbie Seifer's Avatar
    Oct 2004
    Sydney, Aus
    mate, find an old case or even real old pc from somewhere, i picked up an old one for about 15 bucks, so from that i oculd salvage the mobo riser, atx power supply, (for in the house) plus dismantle all the buttons and leds from the front to use on ur new system. Salvage like a vulture.
    My baby is done ...Go the soarer
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Seifer
    Yeh, that too.
    <off topic>cool! you have the previous gen of my car </off topic>
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. 12v Power Supply at MP3Car.com store
    By mykolJay in forum Power Supplies
    Last Post: 02-02-2006, 10:17 PM
  3. Simple Idea for keeping power to inverter while cranking....
    By syclone477 in forum Power Supplies
    Last Post: 03-23-2004, 10:03 AM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 11:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
