Results 1 to 3 of 3
Thread: Set up stage in need of help desperatly.
    Nov 2004
    Ok a few more question. Again thanks for all of the help everyone.
    Here's my system.
    M10k Mobo
    Lilliput 7"
    90w opus
    5.25 dvd player
    3.5 120 gig hd
    1. I've been setting up the software today. I am very confused on setting up frodo but I don't know a direct question to ask. Maybe how do I set it up to run on startup?
    2. I made the mistake of running a program called set res that I got from Frodo trying to make the screen look crisper and it screwed everything up. My lilliput now says out of range and my normal monitor says that is can't recognize it. How do I fix (reverse) this?
    3. I bought my 8 gauge wire and fuse box from a local car audio store. The guy there just gave me some 70v fuses. Will these work or do I need something different.
    4. I just bought microsoft streets and trips gps. I'm wondering if I should keep this one or get the garmen gps?
    5. Is there anything out there to make grounding easier or should I just find a clean piece of metal and screw into it. Or should I run a wire back to the - of the battery for the ground.
    6. How do I set the screen to 848 x 480. I've read that's best I can get.
    7. Sorry so many questions.
    8. Does frodo's dvd player keep the place of your dvd when you pause it and hibernate or standbye.
    9. What is better hibernate or standby?
    10. Should I use frodo as my front end or is there a better (easier) one?
    Ok I'll end this for now. I'm sure I'll have a few more questions but this is getting really long and I know I don't like reading too long of questions so i doubt anyone else does either. Thank you everyone so much for all of the help.
    Elsewhere
    Quote Originally Posted by TimStark
    Put a shortcut to FrodoPlayer in your Startup menu.
    This is basic Windows stuff.
    Since you're flying blind due to the pooched screen resolution (assuming you're runnin WinXP):
    Ctrl+ESC, C, D, D, ENTER, Ctrl+Shift+Tab, <-, <-, <-, Alt+A, Y
    (<- is supposed to be a left arrow)
    Also, for ******* up your screen resolution to the point you can't see anything, you deserve a nelson.
    It works, doesn't it? Why ditch it if it works?
    Clean metal is the better choice, always. The frame, if at all possible.
    1. Get a video card that supports that resolution, like an nVidia chipset card.
    2. Force that resolution using PowerStrip, or a similar program.
    This wasn't a question.
    Why don't you try each setting and make that determination? Some people have had good results with both for different hardware setups.
    That's purely subjective.
    If you want a real answer, download the other front-ends and try them out to make your own judgement.
    How about the Wiki?
    xtm
    xtm is offline
    Oct 2004
    Use Search, NJ
    The easiest way is to put a shortcut on your StartUp directory... BUT you can also make it load faster by making it a shell so it loads first before explorer.exe More info here
    70V... but what's the Amp rating? (you will see something like 30A, 60A, etc)
    How many amplifiers and how many watts RMS do you have?
    You're comparing apples and oranges here. The Garmin GPS is portable, expensive, and rigid... MS S&T is a software bundle+GPS mouse designed to use on laptops and carputers. Buy whatever fits your need. I have MS S&T and I love it.
    DO NOT run GND wires back to your battery! (there is no point in doing so)
    Assuming this "ground wire" is for your amplifier, make it as short as possible. 4 awg is good but 1/0 awg is preferred.
    Right click on your desktop-->Properties-->Settings, Change the screen resolution here.
    It's all personal preference. This is like asking "Who should I vote for-- Kerry or Bush"?
    Anytime
    CarPC Status: 0%[••••••••••••---]100%
    Smashed 4" Lilliput
    66 Mhz Pentium Pro
    400MB Ultra 33 IDE HD
    EISA VGA card (16 colors)
    Windows 3.1
  1. Dual monitor set up and function?
    By dogger in forum Newbie
    Last Post: 10-09-2004, 08:58 PM
  2. Replies: 9
    Last Post: 08-26-2004, 08:59 PM
  3. planning stage is almost complete!
    By pdub in forum Newbie
    Last Post: 07-16-2004, 12:02 AM
  4. need help with my set
    By CorollaVerso'04 in forum Newbie
    Last Post: 04-18-2004, 04:32 PM
  5. X-Mp3 Stage 1
    By hijinks21 in forum Show off your project
    Last Post: 09-28-2003, 02:40 PM
