Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 1000w inverter to much for xbox and psone lcd? and hard drive mounting?
    Nov 2004
    Seattle, WA
    how much will i really need to power xbox (dvd drive removed) and a sony psone lcd? anyone know if the lcd can run straight of 12v? or is it safer to have it powered out of the inverter?
    should i mount my hard drive directly to my trucks interior using some spring system? or is it safer in a custom case, mounted vertically?
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    Check the power rating on the bottom of the XBox. You can probably do it with a 300W, maybe less.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    an xbox draws 100 watts
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by caseyhalone
    mount it vertically (so the disk spins in the same direction as the wheels) to something that wont be moving/bouncing around in the truck. so if you make a custom case, make sure the case is mounted solidly to something in the truck.
    rebuilding carpc... kinda..
    Feb 2004
    Las Vegas, NV
    Quote Originally Posted by studmonk3y
    Damn, serious? Better get my Kill-a-watt out for a looksy. Crap, I don't have an x-box.
    Variable Bitrate Bodgy's Avatar
    Nov 2003
    Briz Vegas, Australia
    Quote Originally Posted by fantomas
    thats debated regularly
    Constant Bitrate Vorex's Avatar
    Nov 2004
    Lake Worth, FL
    How are you getting your xbox to boot with no dvddrive? you should be getting error 7, share your sekrets
    - Vorex Out
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    A modchip.
    Quick! To the Popemobile!
    Nov 2004
    Quote Originally Posted by Vorex
    I have a Xecuter 2.3Lite and 4981(or something, i dont remember) bios version and in one of the config programs i can disable the search for a dvdrom during boot-up.. i havenīt tried it though.
    check out www.xbox-scene.com and you will find many hot tips for your xbox
    Nov 2004
    Lake Worth, FL
    I have 5 chipped xboxes (including one x2.3lite) and none will play nice without a dvd drive =/
    - Vorex Out
